I am pretty much new to cycling...This past summer i got a very very gently used old Fuji bike...it is a Fuji Sagres. Not sure exactly how old it is. I participated in two Triathlons last summer. They were awesome and i am completely hooked on them. Before Tri season comes up again i want to help my bike out. What are some good steps to start rebuilding my bike some. I had problems with it shifting into gears on my back tire also and some times when trying to shift into my big ring in the front my chain would come off.
Thanks!
Thanks!
Bikes: Trek 4300 X 2. Trek 1000, Trek 6000
Originally Posted by slow_xc_star
what is friction shifting?
and what are clincher tires...what other kinds of tires are there?
tubulars are the other type of tire. they are just a tube with a rubber tread on it, and they are attached to the rim with glue.
Bikes: Cannondale M2000 and Trek 970
what if it's friction shifting?
Originally Posted by Coda1
I would do the same for ..... or friction shifters.
Guest
Posts: n/a
So i have concluded that i have index shifting because it clicks when the gears shift...right??? So i should replace the cables and housing and clean/adjust the derailers?
BEst of luck.
Scoob
Bikes: Litespeed Firenze / GT Avalanche
Also have a look at the special tools that you will need. Don't go tearing your bike apart with a crescent wrench and a hammer.
The Park site listed above will explain them.
