De-noising your fenders
Guest
Posts: n/a
Quoted: Post(s)
Anyone have any success in getting rid of the ratting and squeaking from their fenders? I would love to hear what you have to say.
So far, I've used home-made rubber washers from old tubes to go between the strut and the eyelet on the frame and in the brake-bolt mountain hardware. I eventually got some of the leather washers that Velo Orange sells. Other than that I've wrapped some cloth tape (gaffer's tape) around the fender at the point where the rear brake-mount bracket attaches (sks fenders).
Still no dice. On smooth roads they're quite, but smooth roads here are a freakish anomaly. The noise is driving me insane.
For what it's worth, this is a KHS 100 track frame, so clearance is minimal. I can't run fenders with anything larger than a 23mm tire. It's possible that the fenders are rubbing at some other point, maybe against the brake calipers. Who knows. Any help is appreciated.
likes bikes.
i'm gonna attach an extra stay on the front end of my velo-orange front fender. it currently rattles quite a bit on the front end with only one stay on the bottom end. i have the leather washers installed too.
I have a set of SKS fenders that are completely noiseless but they are plastic.
I'm about to install some Honjo fenders so I'll be looking to avoid noise and watching this thread...
Señor Miembro
The only times my Freddy Fenders make any noise is when I hit a small bump while riding with no hands. And even then it's only a slight rattling sound. The moment I put any pressure on the bars they become silent.
Bikes: Surly Pacer, Trek 520 & gaspipe fixed gear beater
I have Honjos aluminum fenders. They're almost as lightweight as the plastic fenders I had beforehand, but the mounting system is more solid and they don't rattle or make any noise at all.
actin' the foo
Bikes: several
ugh.
ugh.
Bikes: Trek SU100, Surly Cross Check
I had some rattling since my frame didn't allow for me to attach the auxiliary mount, so I had to jimmy rig it to increase its stability.
you know that putty that you can use to hang up posters? you can buy those in packs (sticks) and ball them up to form in the area between your fender and frame/fork. they semi adhere but they are really easy to remove. it will absolutely quiet your fenders.
Hello
Yes to above , look for contact points. noises are some time hard to track down. While riding if I here a reoccuring noise I will stop and tap around to try and recreate and localize. My fender contact rattlle point is between rear fender stays and rack struts. Choose your cure. Cork, leather or rubber are all nice.
I spent way to much time trying to find an unusual noise from disposable water bottles. The other day I had a new noise and pulled over into a parking garage only to realize it was a carabiner on my belt loop with a house key.
