Chain Ring Teething Problems
Old 07-19-08, 06:40 AM
Single Speed All the Way!
Bikes: Too Many to list!
Hey
I just had a new chain ring and chain fitted today and while riding home I noticed how noisy the new set up was! Im am now riding a 48T/16T with an SRAM SS Compatible 1/8 Chain (but it was pretty cheap).
My previous setup was ultra quiet so I'm a bit worried....
Any Ideas?
bigdazfaefife is offline
Old 07-19-08, 06:49 AM
Are you using your old rear cog? Might just be from the different wear they've experienced, could settle in with a little wear, (everything should be changed together - ideally).
That's just a guess, can't thnik what else could be making it, haven't adjusted chainline or anything have you?
Mistawes is offline
Old 07-19-08, 06:53 AM
Yeah I stuck with the same sproket (was still in top condition).
I actually took it to a bike shop so any adjustments should be sound (they're pretty reputable)
Old 07-19-08, 06:58 AM
Cool Fresh Classic
deaonerox's Avatar
Bikes: Univega Nuovo Sport Fixed/SS, Mercier Kilo TT
Sounds like what happened to me. I switched my gearing from 52/14 to 46/16. I changed the crankset and BB myself, but I took it to the LBS to change the cog. After they switched my cog, I started 'hearing' my chain moving. Either I've gotten used to hearing it, or it stopped being noisy, I don't know...
deaonerox is offline
Old 07-19-08, 07:12 AM
Perineal Pressurized
dobber's Avatar
Actually, no. If you maintain your chain and change it before it shows excessive wear, your cog should last quite awhile. And a chain ring should last almost indefinitely.
Try a bit more slack in your chain.
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
dobber is offline
Old 07-20-08, 10:41 AM
Liked 12 Times in 1 Post
teething problems? try rubbing a little bourbon on them...
dookie is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
