Seeking Advice
Seeking Advice
I'm hoping to get some good advice from members of this forum. I'm thinking about getting an electric bike to help me get back and forth from my home to various places I go in the nearby town. It is approximately 7 or 8 miles to town from my home. I do not currently own a bicycle, so all trips are done by car.
I've attempted to gather some info on current offerings, and here is some of what I've found:
Curry eZip -- SLA battery, 450W motor with separate chain drive, weight 72lb, claimed range is 18-25 miles, price ~ $400
Ecobike Elegance -- 36V-10Ah lithium battery, direct hub 360W motor, weight 52lb, claimed range is 25 miles, price ~ $1700.
Schwnn Continental -- 24V-10Ah lithium battery, direct hub 180W motor (pedal connected by shaft drive, so no chains), weight unknown, claimed range 40-60 miles, price ~ $2080
Bionix PL350kit on a $500 bike -- 36V-10Ah lithium battery, direct hub 350W motor, weight 50lb, claimed range is 60 miles, price ~ $2200
Obviously the eZip has the most attractive price, but I find that not all are satisfied with it. There are concerns about removing the rear wheel if one needs to replace a tire.
The bikes with the lithium batteries come in much lighter, but the price is high. Which do you think offers the best value, the eZip or one of the bikes with the lithium batteries?
I'd start by determining which battery is right for you, as far as voltage and type. The higher the voltage, the higher the top speed.
I am not 100% sure on the top speeds, but I think 48 volts will put your top speed in the upper 20-low-30s mph.
36 volts--low 20s.
24 volts, mid teens. 36V seems to be the most popular compromise.
As far as battery type, Will you need to lift your bike to store it? Do you live up a set of steps? You may be able to get away with using cumbersome Sealed Lead Acid. SLA batteries are a bad idea if you have to lift the bike because of their weight. At $50, 25lbs of 36V 10ah SLA will last 100-200 cycles. If you can invest more money up front, LiFePo4 batteries are the latest thing and 10lbs of them will last 1000+ cycles for around $400 at best price.
If you piece together the battery, the kit, the bike, a better rim, you should be able to keep things under $1000 with a modern battery.
Are you going to buy your bike secondhand on craigslist?
Ampedbikes.com has a great price on a front hub kit, with an upgraded rim. Goldenmotor.com has very inexpensive front and rear hub kits, but will they will need a better rim, and you will receive a beat up looking and possibly damaged package, guaranteed. For many, the price is worth the risk.
If you search for Ping's batteries on eBay, you can have a LiFePo4 battery at a greatly reduced price, but it will require some polishing up, so to speak.
7 to 8 miles to work is a suitable range for SLA and some pedaling, are there many hills on your route? Keep in mind that SLAs hate to sit in a partially discharged state and it will reduce the batteries life if you can't plug it in to charge at work as well as at home. If you go LiFePo4, no worries, charge it only once daily.
Hope this helps.
36 volts--low 20s.
Hope this helps.
The advertised range of an ebike is usually exaggerated. All claims consider that you are a lightweight athlete and will provide equal assistance by pedalling. I don't know the exact figure but guess you can cut the claimed range by 30% +.
Range (and speed) will decrease by a factor of your hilly terrain, your weight and the total weight on the bike and will increase by a combination of higher battery amps and volts and improved battery chemistry. Street tires are a plus.
My experience is with front wheel hub motors which you can start with a cheaper, SLA battery set-up and if you decide its good you can upgrade to a better chemistry like lithium (and a new charger of course).
You mentioned one kit. I started with a cheap bike and a Wilderness Energy 36v kit (roughly $500 - bushed kit $400) and it is great and can be upgraded to 48 volts and better chemistry. I weigh 240 lbs and get 18 to 20 miles on flat terrain with no pedalling.
Lots of threads here praise the eZip and it seems a good value but I don't have first hand knowledge. I believe its 24 volts.
Thanks for all the information. It gives me much more to think about.
I do not presently own a bike, so I am inclined to buy a finished unit and not piece together a kit. But after looking at the ampedbikes and goldenmotor links, it seems possible to put something together for quite a bit less with a kit.
I am retired, so my interest is more in using it for frequent trips to the grocery store, post office, etc. Obviously I would not be able to charge it up except at home, so I would need to go around 15 miles without charging the battery. I am able to pedal the bike on the straight and level, and I think that would be fun much of the time. Living in Arizona, it would be nice to have more assist on the hot summer days, however. My housing development has an entrance road that rises a couple of hundred of feet in elevation over about a one mile distance. It would therefore be nice to have assist available at the end of my trips.
Anyhow, thanks for all the help!
Bikes: Custom built tourer, custom electric bike, beaters everywhere
One more thing. Unless you spend the big bucks, you will get a pretty poorly made bike, with a first-generation drive. That will probably be okay for the distances you are going. It will also buy you some time to build up from a kit. All you need is a good quality bike, a kit and a few hours time.
Assuming you are going with the pre-built, keep in mind that manufacturers are very optimistic about both range and speed, even with full pedal assist. Don't let your SLA batteries go fully flat and un-recharged. You may only get a couple of hundred charges out of them at best before they become landfill.
Good luck!
Good luck!
Bikes: xtracycle, electric recumbent, downtube folder and more
As far as range with a hub motor, I think Andy at FalconEV has it about right. With LiFePO battery, it works out to be 1 mile per amp hour with little or no pedaling. With SLA it is about 3/4 of that. Since you don't have a bike now you won't be able to help as much when you first get your bike as you will be able to in 6 months.
You might also consider an inline motor like Electroportal or Cyclone (same kit). Being retired, you may consider a recumbent for comfort. I use an EZ-1 recumbent with an Ecospeed inline motor for my utility ebike. It is more money than you need to spend, I use it for hauling 8 foot long trailer filled with my construction tools. Look on Craigslist for a used recumbent, Americans don't use their bikes much so they are in great shape if you buy used. The bikeE AT (with the shock absorber under the seat) is also easy to put the E-4 kit on (Electroportal calls their recumbent kit E-4). The knock against recumbents is they don't do hills well but once it has one of the 7lb E-4 kits installed, it is great.
Hub motors are easy to install and are very quiet but are heavy and not as efficient as an inline motor. The inline motor is easiest to install on a recumbent, though Cyclone has one that goes on a diamond frame bike (haven't tried that yet) but is more complicated to install. The inline makes more noise, less than a car going by but you can hear it until you get up to 12 to 15 mph, then the wind blots it out. The Lithium Iron Phosphate (LiFePO) look like they are cheaper in the long run and the performance is much better than SLA. They are lighter and your bike is of course easier to mess with when you have less weight on it. You might consider a system that allows you to quickly remove the battery pack if you decide to go with SLA. This would allow you to lighten your bike quickly if you want to lift it up.
put our Heads Together
Bikes: a mountain bike with a cargo box on the back and aero bars on the front. an old well-worn dahon folding bike
Oh, there are rules?
Bikes: Women's E-zip, and an old road bike from 1980
I've got the eZip you are talking about and I am quite happy with it. I am 51 years old, female, and hadn't ridden a bike for years. The area I live in is hilly, so I use the battery assist quite often, but I also pedal constantly. I think if you are just using it for riding to the store and back, you would be fine with the eZip. If you are riding mostly flats then you won't be needing to push the battery to it's limits, and you can probably get 16-plus miles out of it. It is a heavy bike though, if you need to carry it up stairs or something, think twice! Also, I changed the rear tire by myself, once you figure it out, it really isn't too hard, you have to lift the motor off while you take off the tire, other than that, it's a pretty standard change.
IZip Rapido
Although, this thread is a bit dated, Currie's new I-Zip Rapido should be considered for anyone else in a similar situation. Since the Rapido seems to use the same electrical drive as the E-Zip, maybe Currie will offer an adaptation of this Lithium battery system for the thousands of E-Zips already sold. I'll be watching. Currie should be able to mass produce a plug and play Lithium battery system for a reasonable amount of money.
my schwinn Izip is basically a currie ezip. It uses a 450W motor with a chain drive. And it originally came with 24V 12AHr Sealed lead acid battery pack.
I am very heavy, I doubt that I'm able to sustain a 125W output from my legs, so the bike does the a lot of the work for me.
With continuous use of the motor, I have to carry 2 battery packs to commute 26km ( 15miles?) to work. Based on the time that my 2A charger takes to recharge the bike, I'm estimating that I am using up about 60% of my battery capacity each way. Therefore, 1 battery pack is not good enough, and 2 seems to be a big weight burden for me...
...2 SLA battery packs weigh in at about 40lbs. Yikes!!! It means that I am unable to comfortably pick up the bike from the seat or rear rack. And, sometimes my balance gets a bit off from the unexpected weight.
I've since upgraded to Lithium Ion batteries. The weight of my batteries dropped from 40 lbs to less than 13lbs. In addition, I expect to get about 10 times the life expectancy for about double the cost.
It's easy being green.
Bikes: Trek Beach Cruiser, Sun X-2 AX (bent)
Get the cheap one, and ride until you decide what you want. This is the same advice I give to people who are new to cycling in general. There is no way that a bunch of strangers on the internet can determine your needs. The only way to know is to get the cheap one, ride it, and determine what you do and don't like or want. Then, you will be ready to make the "big decision."
I commuted on Beach Cruiser for about 20 years before choosing an expensive electric bike set-up. It is OK to wait for the "truth."
You might take a look at the Ezee line of bikes, their prices range from mid-market to high. I've used the Ezee Sprint for about a year and have been satisfied with it. I had to re-wire the front light, which is very weak anyway, and that is about it.
my e bike is a treck 7500 with a 350pl bionx. I got good bike and a good kit so i had a good one to start. if i did not like it. I had some thing good to sell. but i like it alot and will keep it a long time .
Electric Bike..purchase/
I have taken to the eGO..electric bike..
It costs about $$1500.00/
But seems to have everything at that ready to use style..
I'm still working on my JOY-Ride..scooter..
but really would consider that product as very good for the money.
