Getting a cog off without a lockring tool?
Old 07-24-08 | 10:41 AM
Anyone got a clever way of doing it? I have Campy and Shimano lockring tools, but no fixed lockring tools. Don't really want to go buy one, but I might need to.
tekhna is offline
Reply
Old 07-24-08 | 10:44 AM
Hobartlemagne's Avatar
Spelling Snob
Bikes: Panasonic DX4000, Bianchi Pista
do the rotafix technique backwards.
or with a spare length of chain, wrap the chain around the cog (wheel off the bike)
and clamp both ends in a table-mounted vice to hold it still. rotate the wheel to loosen it.
The first rule of flats is You don't talk about flats!
Hobartlemagne is offline
Reply
Old 07-24-08 | 10:48 AM
wearyourtruth's Avatar
Ride for Life
20 Anniversary
1. grow a pair
2. grab cog
3. twist
j/k, i have no idea
wearyourtruth is offline
Reply
Old 07-24-08 | 10:49 AM
pyze-guy's Avatar
Yup
20 Anniversary
From: where the sunbeams end and the starlight begins
Bikes: Kona Unit, planet X cx bike, khs fixed gear
Cog, rotofix in reverse. Lockring, I have used a hammer and flathead srcewdriver, but it really messes up the notchs on the lockring.
When sadness fills my days
It's time to turn away
And then tomorrow's dreams
Become reality to me
pyze-guy is offline
Reply
Old 07-24-08 | 10:50 AM
huerro's Avatar
Villainous
Bikes: Trek 420, Cyclops
I've done it with a hammer and screwdriver before. It pretty much destroyed the cheap soft lockring however.
huerro is offline
Reply
huerro's Avatar
Villainous
damn beat me by a minute.
huerro is offline
Reply
Old 07-24-08 | 10:52 AM
Ride your bike to your LBS.
Yoshi is offline
Reply
Old 07-24-08 | 10:53 AM
i'm importlandt
Bikes: conversion fixie
level up your toolset.
toddistic is offline
Reply
Old 07-24-08 | 12:11 PM
tradtimbo's Avatar
Bikes: 1982 Fuji Team, 1979 Raleigh Team Record, 1984 Raleigh Team USA, Japanese Raleigh Super Course, 2000 LeMond Buenos Aires, 90's Schwinn High Plains, 1978? Austro Daimler Inter 10
I'm assuming your question really is: "Can I get a lockring off without a lockring wrench?" becuas you dont need a lockring tool of any kind to remove a cog. cogs can be removed by a number of methods, the best probally being reverse rota-fix.
I'm not sure what you mean by having campy and shimano lockring tools but not having one for fixed. Shimano makes a very nice lockring, and I bet campy does too. You might be talking about freewheel or cassette removal tools?
To get a lockring off without a lockring wrench is diffucult and it still can be diffucult with a proper wrench. i suggest that if you think you'll use it more than once, go buy a lockring wrench. Hozan makes an excellent one. The one park tool makes is not as strong, and the teeth can actually break off.
If your set on removing the lockring without a proper tool you can try with tools you may have at your house. The first i would reach for is a hammer and punch. next I would try locking pliers with a concave surface and gripping teeth. the third option is a drill. the drill method is destructive, but if your not planning on using the lockring again, it can be done. drill a couple small, shallow holes in the lockring right at the notch and then give a few good whacks with a hammer and punch.
Good Luck!
tradtimbo is offline
Reply
Old 07-24-08 | 04:14 PM
c_m_shooter's Avatar
15 Anniversary
Bikes: Soma Pescadero, Surly Pugsly, Salsa Fargo, State Warhawk, Gravity SS, Schwinn Klunker
I've never had much trouble removing a lockring with a pair of channel locks. I actually gave up trying to get a lockring tool, because none of the shops carry them.
c_m_shooter is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
