My wrist is really bothering me.
Bikes: Specialized Crosstrail Expert
Quoted: 5 Post(s)
My wrist is really bothering me. I am not blaming it on biking although my wrists do fatigue a little after an hour ride. I ride arms locked position but I am not at all comfortable with bent elbows. I read that the seat should be as high as the handlebars and my seat is much higher than my handlebars. I am about 6'4" and I can not raise my handlebars on my mountainbike. I tape and fold a lot of boxes in the packaging department so I use my wrists there a lot too. I do not do any heavy lifting.
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
Quoted: 9 Post(s)
Liked 22 Times
You have a bike fit issue. You need to raise that stem up to level with the saddle with a different angle stem, if nothing else. What kind of Mountain bike are you riding? What size, etc. As of now, you're putting too much pressure on your hands/wrists.
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
Quoted: 5 Post(s)
If I knew then what I know now, I would still not know what I should have bought lol. I read a lot from sheldon brown as to raising the seat all the way so that my legs can fully extend without me bobbing left to right with each pedal. But when I dismount there is not to much crotch clearance. I am not hitting, but there isn't a lot of space left. My LBS originally sold me a 19.5" and I exchanged it for a larger 21" bike after showing them Trek's general sizing guide.
Quoted: 12194 Post(s)
Liked 1,497 Times
It's too small.
Mr. Frowny Man
Ive always wondered what was up with seat height. I see a lot of MTBs around town with the kids/person either way down in the saddle and legs bent while peddling, or at the U dairy store today I saw a parked one with the seat post something like 3-4 inches above the neck of the front flat bars. Is that a 'they got the wrong size' issue or are there people that find that comfortable? Some MTB pics ive seen in magazines look set up that way too....im curious, I guess.
Bikes: Old Bike: 1975 Raleigh Delta, New Bike: 2004 Norco Bushpilot
Liked 5 Times
Quoted: 5 Post(s)
Would a trek FX 7.3 solve the problem? Or does any bike manufacturer have models similar to the trek 7.3? A lot of people here really like specialized. I have to ride somewhat upright due to acid reflux/hiatel hernia. Multiple hand positions would be really nice, but not at the expense acid reflux.
I am wearing a weight lifting glove with wrist support on my right hand right now, I think I am going to the doctor this week. My problem hasn't got any better since friday, and today is sunday. I don't think it is the bike alone, but my wrists to hurt a little by the time I get back.
Thanks for your attention clydes and athenas.
Liked 5 Times
I think my saddle is 6" higher than the handlebars. Could be more.
On a threaded stem, there is a single piece that comes out of the top of the head tube that the bars attach to, this is an older style. Threadless have a shaft coming out the top, and the stem clamps around this, with 2 bolts. A threadless stem looks like this:
What you may need is a stem extender, which looks like this:
You can get the extender at Nashbar, for $20 plus shipping, some bike shops may have them.... You need to make sure you get some spacers as well, to fill up the space.
If you have a threaded stem which looks different, then see your bike shop about getting a longer one,
Extending a threadless stem, or raising the bars on a threaded stem, may require that some of the cables be replaced with longer ones, so keep that in mind.
Quoted: 5 Post(s)
It is a threadless as most new MTB bikes are. I will look into either extender, or another bike.
Bikes: Kona Cinder Cone, Sun EZ-3 AX
That very well could be the source of your problem. You have a riding posture similar to a road biker using the drops, but with your wrists turned differently and without the option of different positions. Mountain bikes generally have seat and bar heights approximately the same. You said you're 6' 4"...what inseam pants do you wear...and what bike size are you riding? It sounds like the bike may be way too small for you. By the way, how did you get that long a seat post?
Quoted: 5 Post(s)
OK, those numbers sound reasonable. Perhaps you just misremember the seat vs. bar height. With the sloping top tube, the seat of a mountain bike does tend to look awfully high when it's adjusted correctly.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
If your seat is 6 inches higher than the bars, it sure seems like you need a larger frame bike. I think standover is over-rated. I have a very short inseam (30 inch) for someone 5-11. So if I get a bike with "adequate standover", it ends up being very small. There is more to size than just stand-over for sure.
21 inch sounds small for someone with 34 inch inseam and 6-4.
Perhaps, but not 6" too small. According to the Trek website, the bike has a 31.8" stand-over. The next size up (22.5", the largest size offered for that model) has a 33" stand-over. He's 9" taller than I am, with a 5" longer inseam. His bike is 5" bigger than mine...and the seat and bars of mine are at about equal heights.
Quoted: 5 Post(s)
I went to the doctor today. I have wrist tendinitis.
For the bike my seat was only a couple of inches over the handlebar. From the other angle it look like the seat is much higher. I had the LBS install an adjustable stem, they did not have an extender which raised it up about an inch. I also had them install end bars for an extra position or two. Now I might have to wait weeks to ride again
