Are Compack and regular crank arms the same
Bikes: 2004 Giant OCR, 2002 Specialized Stumpjumper, 2008 Trek 6500 Disc
This may be a dumb question, but are the crank arms on the compact and the regular the same?
What I mean is could one just buy the chain rings for the compact double and replace the rings on a regular chain ring, or does one need to buy a new crank and bottom bracket?
Broom Wagon Fodder
Bikes: Fuji Supreme; Kona Wo; Nashbar road frame custom build; Schwinn Varsity; Nishiki International; Schwinn Premis, Falcon Merckx, American Flyer muscle bike, Motobecane Mulekick
Quoted: 52 Post(s)
Liked 64 Times
Yes. The "Compact" aspect refers to the large difference in toothcount on the chainrings rather than the dimensions of the arms. A standard road setup is going to be something like 39-53 or maybe 39-50. A compact will be more like 34-50 which give you a gear range more like a triple crank without the extra chainring. Arms will be usually be something like 165, 170, 172.5, 175 just like in a standard road double.
So, can I just buy the the chainrings for the 50 & 34 instead of buying another crank?
The current one I have is an ultegra 6500 with a 53 / 39.
The Improbable Bulk
Bikes: Many
Quoted: 5 Post(s)
Liked 7 Times
No.
A modern road chainring usually has a Bolt Circle Diameter (BCD) of 130 mm and a compact crank has a BCD of 110.
With a BCD of 130 (which your Ultegra probably has), the smallest possible chainring is 38 teeth.
This site gives you some information on the subject:
https://www.sheldonbrown.com/harris/chainrings.html
Slow Ride Cyclists of NEPA
People do not seem to realize that their opinion of the world is also a confession of character.
- Ralph Waldo Emerson
OK, Thanks, I will look into getting a compact double crank. With mostly shimano parts, am I limited to purchasing a ultegra crank, or can I buy another brand?
The Improbable Bulk
Bikes: Many
Quoted: 5 Post(s)
Liked 7 Times
I don't know the 6500, but is it Octalink? You are limited to matching the bottom bracket for sure... or you need to change bottom bracket too.
Of course, if you are changing the crank, the extra cost of a bottom bracket shouldn't be a deal breaker.
You could do a search in this forum to find some recommendations or warnings about specific compact cranks.
Really Old Senior Member
Just to add-
"Mountain" type crank sets in the 24/28-xx-44/48 tooth range are also typically 110MM BCD.
Quoted: 2026 Post(s)
Liked 1,095 Times
Yes, the FC-6500/6503 cranks are Octalinks. Current Shimano compact cranks are all Hollowtech II, AFAIK and aren't usable with any square taper of Octalink bottom bracket so a new bb is a must.
Liked 1,095 Times
There are still some "Treking" cranks with 110/74 bcd available. Nashbar offers one pretty cheap ($70) and it uses an ISIS bottom bracket. Here is their listing:
https://www.nashbar.com/profile.cfm?c...0Road%20Cranks
Broom Wagon Fodder
Quoted: 52 Post(s)
Liked 64 Times
You may need to look at your front derailleur as well. Some will only handle a difference of 13 teeth between the large and small chainring.
What's your real problem? Is the crank bad and you need to replace it, or do you just want a wider range of gears? The easier and cheaper answer might be to change your cassette. If you have an 11-25, your rear derailleur can easily handle 11-27. It might even go to 28 in a pinch (though probably no higher). 39x27 might be low enough to suit you and it would be a LOT less expensive than changing the crank.
Liked 1,095 Times
There isn't anything wrong with the current crank. I was just looking for more capability to get up some the big hills here. The cassette is 12 / 26. So, I will do a search among the different compact cranks to see if there is any to avoid.
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
Get the best of both worlds and get a triple crank. That conversion is a little more expensive if you have to replace the derailleurs (some report not having to), but the result will be worth it.
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
He might also have to replace the left STI lever. I believe for Shimano they are designed to be double or triple-specific.
I already replaced the shifter with the 105 ST-5500. So, it may be better to look at the triple crank instead of the compact double.
How do you find out if the derailurers are compatable with a triple?
Elitist Troglodyte
The part number mostly. The RD should be a long (actually medium) cage version, and the triple FD has a wider and deeper cage.
- Will Rogers
- Will Rogers
