KMC missing link connector
Old 08-05-08, 08:53 PM
ParaWK4's Avatar
Bikes: 85 Fuso, 86 Peloton, 84,88 Paramount
I am trying to install a KMC chain with a 'missing link' connector. This one has both pins attached to one side plate and the other side of it is an oval shaped connector that is supposed to somehow slide onto the pins on the other side. It does not seem to me that the oval connector is long enough to slide on and over the pins. What's the trick ???? I have used the ones where there is one pin on each side plate and you squeeze them together to release, this one is definitely different.
ParaWK4 is offline
Old 08-06-08, 06:06 AM
onbike 1939's Avatar
Bikes: Airnimal Chameleon; Ellis Briggs; Moulton TSR27 Moulton Esprit
Quoted: 3291 Post(s)
Liked 827 Times in 583 Posts
^^^^ It does fit but it can be tricky.
onbike 1939 is offline
Old 08-06-08, 12:03 PM
Elitist Troglodyte
DMF's Avatar
Bikes: 03 Raleigh Professional (steel)
The face of the connector shown in the pic above should be facing outward.
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
DMF is offline
Old 08-06-08, 01:56 PM
Bikes: Gunnar Sport 105/UDi2, previous: Lambert, Giant FCR3, Cannondale Synapse Carbon 105, Specialized Roubaix SL4 Comp UDi2
Quoted: 29 Post(s)
Liked 18 Times in 11 Posts
Here is how I did it. Put the plate with the two attached pins through the two ends of the chain. On the loose flat plate side of the “missing link,” note that there is a slightly wider part of the slot that is big enough for a pin to go through. Next take the flat piece of the “missing link” and put it over one of the pins on the part of the missing link that you have used to join the chain. Then slide the flat plate all the way down the slot so that the pin you put through is on the opposite end of the slot part that is enlarged. Grasp the chain and slightly bend the “missing link” so the ends of its pins move slightly closer to each other. Move the slotted plate so the other pin goes through the enlarged portion of the slot. Finally, grab the chain and bend it back the other way so the two pins of the “missing link” are at the extreme ends of the slot.
flanso is offline
Old 08-06-08, 06:43 PM
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times in 19 Posts
Don't bother using that shyte. Just connect the chain normally. I'm guessing it's a SS/fixed 1/8 chain?
operator is offline
Old 08-06-08, 07:16 PM
That connector works awesome.
ultraman6970 is offline
Old 08-06-08, 08:59 PM
ParaWK4's Avatar
Not a SS -this is going on an 86 Paramount with a 6 speed freewheel. The 'trick' appears to be that my side plate with the two pins is bent so the pins angle out slightly. I have not tried to straighten it out but certainly seems to be the reason it doesn't fit.
ParaWK4 is offline
Old 08-06-08, 09:40 PM
That's intentional. You put in one pin through the hole in the oval, slide and then rotate the oval so that the hole in the oval lines up near the other pin, and then bend the opposite direction (bring the pins closer together) to get it to snap in place. Once you let go the spring in the pin-plate spreads them again and you're gold.
the_mac is offline
Old 08-08-08, 12:36 PM
Oldpeddaller's Avatar
Bikes: 1970 Holdsworth Mistral, Vitus 979, Colnago Primavera, Corratec Hydracarbon, Massi MegaTeam, 1935 Claud Butler Super Velo, Carrera Virtuoso, Viner, 1953 Claud Butler Silver Jubilee, 1954 Holdsworth Typhoon, 1966 Claud Butler Olympic Road, 1982 Claud
Quoted: 10 Post(s)
Liked 11 Times in 10 Posts
+1, You said it before I saw the post! These are good connectors!
Oldpeddaller is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
