Another ferrule question
I am doing my first build (Dura-Ace on a Seven) and, using documentation available on the web as well as the good advice on this forum, I've been doing OK.
But now, my first snag, thankfully a minor one. The ferrules provided with the DA brake cable kit do not fit into the tops of the barrel adjusters. Should I be using ferrules there at all? Looking at other bikes, it appears that they have (typically plastic) ferrules that do fit snugly into the chamber of the barrel adjuster.
Thanks!
Thanks!
Photos of the whole kit would help. Do the ferrules not fit because their diameter is too large? Do they not fit because they have a short narrow sleeve sticking out the end?
I have a feeling I'm going to feel lame when I get the answer. Thanks!
I've always skipped the ferrules on these. I've had the ferrule seize to the barrel adjuster before, but the housing won't (it's nylon...). Not sure if there are issues with this but my bike is OK for the last four years *knock*
Bikes: Gunnar Crosshairs, Giant Trance, Felt Breed, Marin SS MTB, Felt Pyre BMX bike, oldschool GT trials bike
ive seen some cable kits come with a ferrules that have a stepdown to fit into the barrel adjusters, if it didnt have them just run it without a ferrule. it'll be fine.
btw, nice choice with your bike. I love me my ti frame (lightspeed), rides amazing so i cant even imagine a seven
I have a 1999 Litespeed Tuscany and I can't imagine anything riding any better. But the ti ride inspired me to try this, so we'll see.
Your mom
I like having the ferrules in that location. There's a tendency for the SIS housing (with parallel strands) to mushroom at the tip without them. That said, it would stand to reason that the ferrules provided would fit. Are you sure you didn't accidentally pop a brake cable ferrule on there? I've done it many times.
if you look at the pic he was talking about the brakes. I missed that part until i saw the photo but was thinking the same at first.
ive quit lusting after those light carbon bikes after getting my lightspeed...im all about metal bikes now, good luck with the project and let us know how she rides
I see that you crimped the ferrules. You may have distorted the end just enough that it won't fit now. Try a new cap in there without any crimping. See if that fits. They should fit with just a little slop. Since even a careful crimp will make them sticky at this point don't crimp them. Just slip them on. Even slipped on the ferrule will supply the support needed for the strands under the plastic covering. And with the cable in there and the whole system done up it won't let the housing jump out.
I stopped crimping my ferrules long ago just for this reason.
Quoted: 1855 Post(s)
Liked 664 Times
I also want to emphasize that the brakes should have better and firmer feel with the ferrules, and with the housing ends files flat before ferrules are added. This combination butts the outer cable firmly to the brake caliper, so all cable motion is imparted to the caliper, and not taken up in compressing or distorting the housing. I feel this is important.
So I'm in favor of finding a ferrule that fits your brake. Could it be that several Shimano levels of brake require different housing diameters? Is DuraAce unique?
I have some Modolo cables, whose ferrules do not fit into Campy levers or calipers.
Road Fan
Thanks for all your help!
The crimped ferrule in the pic was one I had on a used brake cable that I tried after the plastic ones furnished with the DA package wouldn't fit. I understand the point about crimping but don't think it's the issue here. Both metal and plastic ferrules are significantly too large in diameter. I have them set up now without ferrules but will keep my eyes open for some stepped down ones. They're working OK for now.
GEEZ guys. DA brake adjusters don't use ferrules! Just stick the end of the cable in and call it good! the ferrules are in the cable kit in case you need them for some frame applications.
