Mounting a tail light on a rack
Ok, I am wondering if I am missing something really obvious here.
Lots of bikes have tubular aluminum racks on them. My racks have nothing specific to attach a tail light. All tail lights come with a seat post clamp, and a clip for attaching to clothing or bags. Only two tail lights I have found specifically mention that they attach to a rack: A topeak tail light on a topeak rack with a tail light mount, and a blackburn mars 2 light that says it can attach to a blackburn rack.
No description or picture is given for the blackburn Mars 2 light attachment, other than "no tools required."
Now, I would think that your rear rack would be one of the first places many people would want to install a tail light. Then things on top of your rack will not obstruct the tail light. Yet no info is given about what lights can do this, and how they do it. Does everyone just chuck the seat post mount, head to the hardware store, and rig their own method?
I have three or four blinkie tail lights, none of them attach to a rack. What gives?
I bought a rear blinker and then realized I could only mount it to my seat post. I put a reflector on my rack and the blinker on the seat post. Maybe I'll try to rig something up though since the blinker would be more effective on the rack I'd say.
Master of the Universe
Planet Bike sells a rack-mount bracket so you can attach a blinkie to a rack. However, you need some way to attach the bracket to the rack...
I have an email into Blackburn customer support asking about the Mars 2 light and the Blackburn racks.
So now I begin to wonder, is there some reason you shouldn't mount a light to the rack?
Unlisted member
Bikes: Specialized Hardrock
Quoted: 1376 Post(s)
Liked 432 Times
I think I saw that one. It looked like something that would attach to a topeak rack. But looking at the parts in the picture, I still couldn't see how I could bolt it onto your typical rack without a trip to the hardware store.
Ahh, so the Mars 2 has a clamp that can go directly onto the rack's aluminum tubes? Please elaborate! Show Pics if you can? And how do you like the Mars 2? It doesn't seem as fancy as the Mars 3, at least by looking at a picture of it.
"Florida Man"
Quoted: 1566 Post(s)
Liked 1,698 Times
I have the Mars 2.0. It has several mounting options. One is to mount in a regular reflector bracket. Since a lot of racks have the reflector mount, you can put it there if your rack has it.
Oddly enough, I have a Topeak rack on my bike, which has a bracket only for their Topeak light. Even more odd, I mounted still another light instead, the same as the big fat one on the back of 10wheel's bike here:
https://www.bikeforums.net/showthread...=437032&page=3
The Mars 2 is an o.k. light; I use it as a blinky, and emergency back-up. The big one really stands out; I highly reccomend. A couple angle brackets and a few minutes, and you could probably make it stick to the rack. I think 10wheel just stuck his to the trunk bag. Good luck.
Wow. that's a serious tail light in your link!
I have always had Mt bike racks, or racks with a metal tray to attach my angle brackets to. The blackburn EX-1 that the lbs put on my bike at the time of sale is kinda minimalist. Nowhere to use an angle bracket near the back, only way to put a light back there is to buy one that clamps to the rack tubing, rig something up from the hardware store to clamp to the tubing, or fabricate a bar on the back for attaching things. Unless the Mars 2 satisfies me, I see a trip to the hardware store coming.
Unlisted member
Liked 432 Times
You need a new bike
There is a "standard" tail light mounting used on many racks. It's two holes spaced apart horizontally. Many of Topeak's fixed racks have this mount.
You need to get a rear light designed for this type of mount. Peter White sells some of them in generator or battery operated.
But look at the picture:
No reflector bracket, no tail light bracket. Nothing but tubular aluminum. Is there a reflector or tail light mount which clamps onto the rack that can be purchased seperately? Or am I supposed to wander the hardware store and fabricate something?
Liked 6 Times
While we're on the topic: I ran into a rack that uses the common metal plate down the middle, and the owner wanted a SuperFlash mounted on it, but there were no holes/brackets/fittings. Solution: I drilled a hole in the metal top plate, then drilled a hole in a piece of wooden dowel that was approximately seatpost-sized, and bolted the dowel vertically to the underside of the metal plate. Then I just mounted the SuperFlash on the dowel, using the seatpost mount.
Well, I have all sorts of ideas on how to fabricate a mount. I just have to decide what kinda stuff I want to put back there. PVC, wood, plastic, metal, all could be shaped and attached so that virtually anything could be attached. I even have some ideas on fabricating a platform that can be velcro strapped on and off the rack, letting the lights hang off the back but below the rack, so that an entire array of lights and blinkies can be put on and removed with ease while still letting the rack be used for a trunk bag or panniers. I guess I will design something once I have decided what I am going to use for tail lights.
But I still find it hard to believe that at least one tail light doesn't come with a bracket to clamp onto the tubes of a rack.
You need a new bike
Cateye sells clamps for their tail lights for various sized tubing. Maybe they sell one small enough for your rack. If not, you could increase the diameter with a piece of inner tube.
If you plan to use a rack trunk, you can probably clip a tail light to it.
Or, you could go to https://peterwhitecycles.com/taillights-bat.asp and scroll down to the adapters section. The T-bracket looks like it could be made to work with your rack.
I have thought about the topeak rack. Integral tail light mount, and the trunk bags that slide on seem good. The rack pictured above would look good on my wife's bike, so it wouldn't go to waste.
I am considering an array of tail lights for my morning commute this fall, about 30 minutes of suburban darkness. If I go that route later on, then I will end up fabricating something to hold them all. I was thinking of a bunch of blinkies, some on constant, some on on blink. Or a dinotte with some blinkies added. We'll see.
But that link is excellent! Yes, that T baracket does look like it would work, I wonder if it is long enough? I will give them a call. Thanks! BF comes through again.
Unlisted member
Liked 432 Times
Sure I can get pics, what did you want to see? There really isn't much to it, the light bolts on to the rack just like a reflector.
no pics needed anymore, but thanks! I had hoped it just clamped to the aluminum tubes. Since I have no reflector mount.. yet... the Mars 2 won't solve my problem. The above pictured t-bracket will fix me up though. Then I can use the Mars 2, or any of the planet bike blinkies I already have with the Planet Bike rack adapter. Problem solved!
Unlisted member
Liked 432 Times
Quoted: 5219 Post(s)
Liked 3,564 Times
Good thread for a rant. Whatever happened to standards ...
Bikes: Trek 7.5 FX, Trek Navigator 2.0
My blinker had a belt clip and also a seat post mount. I slipped the belt clip over the license plate holder on my rack and used a tie to give it from slipping off.
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
Velocommuter Commando
Well, I guess the lbs was just too lazy to put it on when I bought the bike? But if my memory is correct, all three of the racks on the wall did not have any tail ligt mounts. Hmmmm.
I ordered the t bracket from peter white, but before it came, I found a topeak mtx rack with tail light mount at a good price at a different lbs. They also offered a good deal on a mtx trunk bag, so I decided to switch over. But the blackburn rack won't go to waste, It would look good on my wife's bike.
Year-round cyclist
Yes, but it's made of fairly thin aluminium. It'd definitely designed for a standard issue bicycle reflector. It is probably OK for a light taillight, especially if your streets are potholefree, but if you install a Cateye TL-LD1100 and ride in the streets of Montréal, I'm sure it will fall within 30 minutes.
Bikes: 2 many
Liked 323 Times
You typically need the reflector that comes off that bike.
The only good way to do it is to leave the bracket off until the rack is going on a bike. They do get lost or forgotten sometimes.
