What headset on the 2005 Haro F2?
When I pick up the bike so that it is resting on the back wheel and I push on the handle bar, it wobbles as if there is space in the head tube. So I'm guessing there is something wrong with the headset? I wanna find out what kind it has and to see if I can buy parts to have it replaced. Can anyone help?
It supposed to have this headset: TH Power Pro Aheadset 1-1/8" according to the specs on the website (https://www.harobikes.com/2005/bmx/f-series-f2.php#).
OMG! PANDA COMIN' THRU!!!
Bikes: 1999 Diamondback Assault EX (slightly modified)
Depends what you want unsealed or sealed. I can point out two two unsealed that I have liked. The a-head Tank and the FSA Pig headset on the unsealed side. For sealed you can use a Race Face, the new Cane Creek 110 and my favorite the Chris King.
Is it standard, internal or integrated that I need? So from m described problem, is the headset really the problem? Would I also need to get new bearings or a spacer perhaps? I'm clueless at this heh
here homeboy, ummm...
remove your stem and handlebar,
and once that is done tell us which one it most similarly looks like...
cuz' I for one... Haven't had a Haro in YEARS (circa 1999 & 2003)
https://www.danscomp.com/serve.php?ca...l=headsets.htm
So from the problem that I've descrived, there MUST be somethign wrong with the headset? Can anything else cause this wobbly problem?
Live To Ride Ride To Live
Bikes: Fit flow
there might not be enough spacers under your stem to keep the headset tight. loosen the pinch bolts on the side of your stem and then toghten down the compression bolt on top, but gently don't over tighten it.
BMX For Life
We win all charity rides
Bikes: BMX, fixed gear
i had the same problem right after i ditched my gyro and brakes altogether. there is too much space between your stem and headset. all you need is some spacers. those will usually run you a few bucks each at your LBS
