High Pressure Floor Pump
Old 02-10-04, 07:59 AM
Any recommendations on a high pressure floor pump? One that can go up to 200psi or greater? I'm looking at a Silca and SKS, recommendation on either? Thanks.
EagleEye is offline
Old 02-10-04, 08:54 AM
8speed DinoSORAs
Ed Holland's Avatar
Eagleye,
I just purchased the SKS "Rennkompressor" at christmas. Very heavy duty construction with cast iron base, steel pump tube. It cost me £40 (about US $60, depending on exchange rates). This is somewhat expensive, but the construction quality is excellent, and compares reasonably to the other high quality offerings. What influenced my choice was that the bike shop recommended it - it is what they use in the workshop. I believe it's rated up to 170 psi, and getting 700x23 tires to 120 is easy. It will outlive me and my grandchildren!
Hope that is useful,
Cheers,
Ed
Get a bicycle. You will certainly not regret it, if you live.
Ed Holland is offline
Old 02-10-04, 09:09 AM
Bikes: 2012 Trek Madone 6.2
Mine goes up to 120 easy,its called an air compresser.
shokhead is offline
Old 02-10-04, 09:38 AM
Tiocfáidh ár Lá
jfmckenna's Avatar
Bikes: A whole bunch-a bikes.
Quoted: 460 Post(s)
Liked 123 Times in 76 Posts
Ive had a Silca (don't know model I think cost 50 -60 usd all steel w/ wooden handle) for about 10 years. Only now is it acting up a bit but all I gotta do is replace or just grease the cup. I can get 8 bar easily but I dont know about 200 psi?
jfmckenna is offline
Old 02-10-04, 11:36 AM
Perineal Pressurized
dobber's Avatar
Ditto. $30 and a visit to Wally World. You can get a rechargable one to drag around in the car.
https://www.walmart.com/catalog/produ...338#long_descr
Has the added advantage of pumping up the truck tires. Like to see you do that with a hand pump...........
dobber is offline
Old 02-10-04, 01:32 PM
Thanks for the replies. I think I'm gonna go with the SKS, but will keep the air compressor in mind, for the future...not a bad idea.
EagleEye is offline
Old 02-10-04, 10:02 PM
Bikes: Wilier, Giant, Trek, ProFlex
Are you planning to run an air impact wrench off of this pump? Nailgun? No need for that much pressure.
Silca makes a good pump. I have two Specialized Airforce Team pumps and they work great. About $40 - $50. Gauged to 160 psi. Plenty enough.
giantmdb is offline
Old 02-10-04, 10:15 PM
I just got a set of tubulars that can run upto 220psi, so I figure I'd give it a try to see how it feels.
EagleEye is offline
Old 02-10-04, 10:45 PM
gazedrop's Avatar
Bikes: 1998 Bianchi Veloce
Silca floor pumps go up to 220psi/15bar
gazedrop is offline
Old 02-11-04, 01:05 AM
base training heretic
Squint's Avatar
Bikes: Cervelo P3C, many Litespeeds
The pump for my air rifle goes up to and beyond 200 bar. It's 3 stages and generates a fair amount of heat and condensed water.
Squint is offline
Old 02-17-04, 06:59 AM
8speed DinoSORAs
Ed Holland's Avatar
Hi Again....
Made a slight error in my original post - I was using my SKS Rennkompressor yesterday and noticed on the box that it is rated to 224 psi, not just 170 as I wrote before. 170 is the rating on my SKS vector alu frame pump!
Cheers,
Ed
Old 02-17-04, 10:42 AM
Cool! Thanks.
EagleEye is offline
Old 02-17-04, 08:35 PM
Now with racer-boy font!
Moonshot's Avatar
Bikes: 2004 Litespeed Tuscany, Trek 5500, Breezer Storm, Bianchi road bike (fixed)
Silca makes a good floor pump. I've had mine about 10 years. Recently, my pressure guage would show a drop in pressure on the upstroke. I removed the valve in the bottom, cleaned and lubed it and now the pump works like new again. Other than this the only thing I've done is replace the chuck about three years ago.
www.eastalabamacycling.org
Moonshot is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
