Caught in the rain. How soon/much should you grease your chain?
I would be more concerned about all the road grit riding around on the
chain. A good cleaning is in order then relube. A look at the bottom
of the down tube and back of the seat tube will give some idea of what
is on the chain.
is on the chain.
Dry off the chain, cogs and chainwheels with a dry rag or paper towel as soon as you get home. Then reapply your chain lube.
Mad bike riding scientist
You don't have to be in a horrible hurry. The bike won't melt and the chain probably won't rust immediately. Depending on the lube you use, you might not even have to reapply. If you use a oily sticky lube you are probably covered for at least one rain storm, maybe more. If you use a dry lube, you'll need to apply pretty quickly after the chain dries out. I would probably not try to apply any thing to a chain that is still dripping water. Get the water out first either by spinning the drivetrain in a dry place or, if you are in a hurry, you could use isopropyl alcohol (rubbing alcohol) to flush the water out. Don't use WD-40 to do that because it leaves behind other problems.
Generally, dry lubes don't offer much water protection but they don't attract sand and grit. Wet lubes offer much better water protection but they attract grit and sand that then grinds the chain down faster.
Stuart Black
Dreamin' of Bemidji Down the Mississippi (in part)
Stuart Black
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Chains and cassettes don't immediately rust and won't fall apart with rain. cyccomute offers good advice especially the part about don't use WD-40. Just wait for the chain to dry and apply some lube. Ocasionally I forget to apply lube. If my chain needs it, I can tell before I've gone a block.
The only downside to riding in rain is the water and road grime causes more frequent repacking of wheel bearings, bottom brackets, and headsets.
Rat Bastard
Bikes: Cannondale Prophet, Specialized S-Works SL2, Specialized S-Works Stumpjumper
If you're bike has been properly maintained and lubed a ride in the rain isn't much of a big deal. When you get home wipe off the frame with some soft terry towels to remove water and grit. While you're at it, wipe down the wheels. Take your chain lube and really saturate the chain with it then take a rag and hold it to the chain while you pedal the cranks backwards by hand. By flushing the chain and removing as much of the lube from the chain as you can you're taking away a lot of the grit and water. When you're done apply a normal amount of lube and you're good.
Mike
Mike
TWilkins
If I get caught in a bad rain, I'll usually try to clean and re-lube my chain before the next ride. I use Finish Line wax lube, so it washes away pretty easily. Just use an old rag and spin the chain through it until you get most of the old lube and gunk off, then re-apply fresh lube and wipe away the excess.
Depending on how much you ride and the particular type of lube you use, you may need to clean and re-apply it fairly frequently. I just keep an eye on mine and try to service them when they start looking dirty. It seems like I'm usually re-lubing either my single or the tandem at least once every couple of weeks, and during high mileage periods, I sometimes need to do one or the other every week.
that bike nut
Bikes: 2010 Motobecane Immortal Force 90' Trek 1400; 90' Trek 850; 06' Trek 520; 01 Iron Horse Victory
When I'm caught in the rain I use simple green and a toothbrush and rag to clean it. Then I use a Jet hose to flush out more grit and the simple green residue. Then I dry it off with a rag and relub with chainsaw bar oil, backpedal a few minutes then wipe off the excess. Takes 20 min.
Living in London I seem to get caught in the rain quite a bit. but then i did in Sydney a lot as well. Commuting every day it does happen.
I'm lazy so my bike is dirty.
I know that technically I 'should' wipe it down but, meh....there's beers in the fridge that need drinking.
As for chains - I just put some more of that fancy chain lube on it when it starts to squeak. independent of the rain... - i don't get all this anal retentive **** people go on with - its just a bike.
eventually you will need to replace the chain. not worrying about it makes riding much more enjoyable.
Bikes: Cervelo Prodigy
Hey, an electric toothbrush with an oversized brush end!!
A Water Pik filled with Simple Green to water jet out stubborn particles.
Finally, a dental flossing.
Don't tell your wife.
Hills!
Bikes: 2008 Trek Madone 5.5, 2005 Marin Novato, Trek 7100
I can't bring myself to use a water based cleaner on my chain and cassette/chain rings. So I use the dreaded WD-40 as a chain cleaner/solvent every 500 miles, let it dry for several hours and then followup with a fresh lube job using ProLink Gold.
I don't know how chains are supposed to wear, but after 3200+ miles on it, the LBS measured my chain the other day and said it still checks as new. FWIW.
Bikes: Rustbuckets, the lot of them.
If it was ridden in enough rain, the chain is probably already relatively clean. Simply lube with oil. Any oil, even wd40. Doesn't really matter. The most important thing at this point is to keep rust at bay.
