Rear Hub
Old 02-14-04 | 09:33 AM
20 Anniversary
Bikes: Haro escape 8.1 with mods
Rear Hub
how do i tighten my rear hub.. when i wabble the tire side to side there is alot of play.. i dont konw if the hub needs to be tightened or is it the spokes??? please help me!! thanks
Haro26 is offline
Reply
Old 02-14-04 | 11:10 AM
Retro Grouch's Avatar
Titanium Club Membership
20 Anniversary
Most likely it's the hub bearings. To tighten them you need a "cone wrench" to fit your bike, usually 15mm. It looks like an open end wrench that's been on the Atkins plan. You will also need an ordinary 17mm open end wrench.
After you find the necessary tools, you need to figure out which lock nut (there's one on each end of the axle) has come loose. Then you need to tighten the cone on that side, hold it in place with the cone wrench, and use the 17mm wrench to snug down the locknut. The art comes in getting the whole thing adjusted tightly enough that the rim doesn't wobble and loose enough that the rim still spins freely. It usually takes more than one try to get it just right.
Retro Grouch is offline
Reply
Old 02-14-04 | 09:52 PM
Long-winded, semi-helpful
20 Anniversary
Bikes: 2004 Bianchi Veloce, Schwinn 3-speed, coaster-brake road bike, Fuji MTB
That was an impressively well-worded reply by RG. I could never begin to explain that to someone over the internet without an illustration. Hell, I usually show people a picture to explain it in person.
But anyway: just wanted to second the opinion that it will likely take more than one try. And recommend that while you're out getting a cone wrench, you should try to find a good repair manual: almost any will explain adjusting/overhauling hubs. I like Glenn's Manual (I forget the whole name) or Bicycling Magazine's guide to Bicycle Maintenance and Repair. Both have gone through many editions, any of which will cover your hub problem, though newer ones obviously will cover newer developments. But both have lots of step-by-step explanations with photos..
Or if you're in Philly, you could stop by Bike Church / Neighborhood Bike Works and someone will show you how to do it for free. Though if you've got some extra cash, they deserve it..
cheers.
Y.
After you find the necessary tools, you need to figure out which lock nut (there's one on each end of the axle) has come loose. Then you need to tighten the cone on that side, hole it in place with the cone wrench, and use the 17mm wrench to snug down the locknut. The art comes in getting the whole thing adjusted tightly enough that the rim doesn't wobble and loose enough that the rim still spins freely. It usually takes more than one try to get it just right.
yoni is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
