Need some opinions on transmission
X-Large Member
Bikes: 2004 Rivendell Atlantis, 2004 Thorn eXp, 2004 Bob Brown Cycles Custom
Please go to this THREAD and scroll down to the bottom... I need some suggestions on what to do to get some lower gearing on my Trek.
Thank You!
Thank You!
The Red Lantern
The shifters look like friction only. If they are get a frewheel with a lower low gear, looks like you have a 25t. There are not a whole lot of choices with five and six cog freewheels so you might also need to respace the frame to 130 and put a wider axle in the hub, in order to use a 7 0r 8 freewheel. In the front if you went triple you would need a new crank, BB, der and rings. So to save money, if you have a 130 bolt circle, go get a 38t chainring, that is as small as you can go. If you have a smaller bolt circle you might be able to find an even smaller ring but sizes outside of 130, 135 and 110 are uncommon. Fortunatly you live in NYC and I would bet there many out of the way old bike shops that may have the parts you are looking for.
While looking around, keep your eye out for a triple bike the same era as yours, but crashed and cheap. Buy it and swap parts.
Are you a registered member? Why not? click here to register. Its free, and only takes 27 seconds!
Help out the forums, abide by our community guidelines.
I am in the woods and I have gone crazy.
JRA...
Bikes: trek 520 & 736, DeRosa Professional, Fuji Professional, Raleigh International 3-speed, Saronni (any info people?), Humber 3-speed, Raleigh Sports, Carlton Grand Prix coming soon!
Nice bike! Think I have the same year, probably my favorite all-around bike. They should've given it a longer top tube though, too much toe overlap, esp with fenders.
You mention your weight. If you're a heavy guy, I don't think I'd put a longer axle in, you're going to break it, esp. if you're loaded. Or carrying stuff.
Shimano makes 6- and 7-spd megarange FWs. the 6 is available as a 14- or 13-34, the 7 comes as a 11-,13-, and 14-34. Might be the cheapest option. Keep in might this is serious "bail-out" gearing, they all jump from 24T to 34T. $25-$40 if you do it yourself.
Second and maybe more sensible is a 110 bcd crankset. Sugino makes a really nice one, comes 46-36-26 stock. Might involve a BB as well.
If you decide to respace the frame for more gears and better selection, get a cassette wheel, preferably 135 spacing. Stronger wheel overall.
Keep in mind you're almost certainly going to need a long-cage derailleur, whatever you do.
JRA...
I should've prefaced above with "How low and what are you doing with the bike?" 14-28 freewheels are easily available, and there is a good chance you keep the derailleur on there.
