crank?
Yeah, just take out the inner ring and tighten up your inner limit screw. Unbolt the cable-clamp screw and tighten up the cable.
Insane Bicycle Mechanic
Quoted: 803 Post(s)
Liked 704 Times
Been there, done that. I have a Bianchi Alloro that I wanted a "compact" double crankset, so I installed an old set of Deore crankarms with 36/50 chainrings. It works fine.
Jeff Wills
Jeff Wills
Bikes: Trek 1000, two mtbs and working on a fixie for commuting.
Unless you have a really cheap crank in which they are permanently attached together.
