Lessons learned
Hills!
Lessons learned
I almost hesitate to share this story because I feel pretty dumb. But if it helps someone else avoid a problem, it will be worth sharing a story that highlights a bad call on my part. I always seem to have to learn lessons in expensive and painful ways, and the trend continues.
Yesterday on a group ride, I crashed hard. Nothing broken on me (that I know of) or the bike, but I have a lot of soreness and pain to deal with. It broke my helmet and I have some pretty good sized goose eggs and abrasions, etc. Shoulder and hip are pretty painful too. I'll probably go see the doc tomorrow just to make sure I don't need further attention.
The cause of the crash was entirely my fault. I was closing on the rider in front of me and violated his wheelspace. I hooked a wheel when that rider suddenly moved over, not knowing I was there and down I went, fortunately on the grassy side of the road.
In retrospect, I should have just drug a brake to kill the closure speed and stay out of his wheelspace. But as I've done many times before (with no issues), I just eased up and moved off to one side of the rider I was closing on, just getting my front wheel inside his wheelspace while my speed bled off so I could maintain my spot in the paceline.
If you're going to get in somebody's wheelspace, make sure they know you are there. Either pass them or stay behind them, but don't get in that blind spot and expect to emerge unscathed.
Lesson learned... the hard way, of course.
Boomer
Bikes: Diamondback Clarity II frame homebuilt.
Quoted: 16098 Post(s)
Liked 1,457 Times
I'm glad you broke your helmet...................
Cause it might otherwise been your head.
ROAD enthusiast
Been quoted here many times on BF "protect your front wheel!"
Every ride out I start with saying to myself "Make it home in one piece"
Lincoln, CA
Bikes: 94 Giant ATX 760, 2001 Biachi Eros, 2005 Giant OCR2 Composite +
+1 on the communication. Even with a mirror there is at least one blind spot. On a multiday ride with 2500 riders, I used a little toy store horn to announce that I had pulled up behind. An and "on your left" if I was to pass (we were all atuned to the "on your left". It's a little harder in small, casual groups, because you feel a little silly, but it's better than a broken helmet.
Thanks for posting. We all need these fundamental reminders.
Truth is stranger than reality.
'96 Giant ATX 760 MTB
'01 Bianchi Eros
'05 Giant OCR Llimited Carbon Fiber + upgrades
'01 Bianchi Eros
Find a similar size friend and head out to the local grassy area. Riding slow, take turns bumping into each other's hips and shoulders (you can actually get to the point of leaning onto each other's shoulder and ride for a while like a pyramid) .
Then try rubbing wheels , bumping in from both sides. After a few spills, you'll learn how to react without getting taken down.
Hills!
Thanks for the well wishes all. Unless I find out otherwise from the doc tomorrow, I'll be back on the bike ASAP. I hate it when stuff comes up that interferes with my bike riding... and conditioning. Ah well, life happens.
Honestly, I'm not sure I have an interest in learning to ride like this. While there may be value in bumping wheels intentionally, do the same bumping dynamics at low speed operate at 20+mph? I sure as heck don't want to do 20mph wheel bumps just to learn a new skill that I hope never to have to use. Or am I just sticking my head in the sand here?
Hills!
I've been lucky so often in this regard that I came to think nothing of it. My thinking has dramatically changed after yesterday's experience.
Ignorance is bliss, they say. Just wonder what else I'm blissfully ignorant of...
Hills!
I figure for $30 or so for a new helmet, it's not worth the effort to get the helmet replaced. But that's an interesting story. Wonder if anyone here has had their helmet replaced after a crash?
On the road again
Bikes: Specialized Roubaix, Cannondale R6000
First off, glad you are in one piece. I once did the same thing and ended up with a cracked rib and a concussion, found that out later that night after riding back 20 some miles from where I crashed, fortunately didn't take down the guy in front or behind me.
With respect to the helmet replacement, it all depends on the manufacturer and the type of helmet. Bell has a deal on some of their higher end helmets where you get 30% off when buying the same helmet you cracked. Most LBS know the offers and will process the discount and/or replacement.
"We're high with expectation on the edge of the unknown."
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
Having lost a valued friend and mentor in a similar incident, I always maintain a safe following distance, just as I do when motoring. My friend struck my rear wheel 160 miles into a double century, sustaining a blow to the temple. He completed the ride, headed out for a third century, and struck another friend's rear wheel at the 220-mile mark. This time he went into a 3-week coma, then expired when moved to another hospital. He made a number of mistakes that day, and the cumulative effect was tragic. A helmet would have helped in these relatively low-speed falls against the curb. Stopping after the first fall, or at least at the 200 mile finish line, would have helped. Not drafting so closely, not trying to be so efficient, would have helped.
Years ago I was a bit of a hell-raiser and hugged others in group rides. Wheel touches took me down a number of times. With all the accelerations and slowdowns in group riding it's not always possible to feather the brakes lightly or quickly enough and, besides, gripping your brakes tends to make the overall group more jerky and unpredictable. Being mindful of the wheel overlap with the guy in front helps...but don't look down constantly-- better to look ahead a little past him mostly to anticipate the group "flow".
Fully agree with speedlever above that practicing "bumping" at low speeds is good. Often, it's the sudden shock and surprize and then over-reaction after contact that brings us down.
At 60, I feel more brittle and vulnerable these days and mostly avoid the dumb moves I once thought were fun. Once in a while, however...........
Hills!
My crash happened so quickly, I'm not sure what happened although I know what caused it. I don't recall the mechanics of the fall itself. When I saw that rear wheel move over, I knew I couldn't avoid it and knew what was coming although I've never hooked a wheel before... and don't care to do it again.
I haven't ridden pacelines all that long. But I was taught to tuck in closely to the rider in front to draft. There's close... and then there's too close (wheel overlap).
I'm glad no one else went down due to my error.
I figure for $30 or so for a new helmet, it's not worth the effort to get the helmet replaced. But that's an interesting story. Wonder if anyone here has had their helmet replaced after a crash?[/QUOTE]
I crashed pretty hard a month ago by rubbing my front wheel against a sharp transition between the shoulder and the road. I have a bruised hip, a cracked rib, lots of road rash and a cracked helmet. I cannot imagine the blow to the head I would have had without the helmet. Anyway it was a Trek helmet and I did send it back and they replaced it no charge.
