Kinetic Road Machine Questions
Bikes: Cannondale Prophet Lefty
I set up a new KK road machine tonight. Really would like some input. Should I see black tire lines on the roller? I am assuming its from the heat. If it matters, the road bike tires are brand new.
Do I have to use the tension dial in conjunction with the gears to get the feel of a high gear? For example, when I use little tension and rely on shifting gears its not enough to stand. Finally, I realize this is not the technical term, but I get sort of a pedal slap, even when the tension is tighter and I am on the most difficult gear. It's like having it on a lower gear and going to fast and hearing that slap with each rotation on a real ride. I hope that makes sense. I am new to this, so I dont have all of the right lingo. Thanks
Bring the roller to a tire so it just touches the tire.
Make sure that the tire has been inflated to max. sidewall pressure. Slick, no thread narrow tires (23C) are the best to use on any trainer.
Tighten knob 2 complete revolutions.
That should do it. It is normal to hear and feel a slipping sound upon start up. But you should not hear it once the freewheel is up to speed. If you attempt large sudden changes in speed you will also get slippage.
The gears should be adequate to provide all of the resistance you need, unless you are Lance. In which case you can increase the resistance by holding the flywheel and tightening the bolt that holds it to the rollers. The factory set bolt tension is fine for 99% of us mere mortals. If you bought the unit used, maybe the previous person messed with it.
The black on the rollers is from tire slippage. You should not see a whole lot of it. Make sure you are at max pressure. and you did two complete knob revolutions.
There is a tire that conti makes that is only for home trainers that will not leave rubber and is excellent for preventing tire slippage and saving your tires:
https://www.biketiresdirect.com/pcouh...er_tire/pp.htm
You can't use it on the road, so if you do a lot of trainer and road workouts it's not worth the hassle of changing the tire. Some folks just use a spare wheel when they are on trainers.
Can't help you on the "pedal slap" since I don't know what you mean - unless you are referring to the slippage.
The slap you are feeling w/ little tension is slippage between the tire and roller - you need more tension.
Bull
Is the Skewer that is included with most trainers for bikes without or is it designed for the specific trainer and should be used instead of the factory one? I know, dumb question but I thought I'd ask since I'm new here and to the sport.
Cornish Mafia
Get the Conti trainer tyre, trainers eat normal tyres for breakfast!
Quoted: 15 Post(s)
make sure your tire is clean
the dust will cause the tire to slip
use a wet dish scrubbing sponge and some windex
you can drill or scratch a mark on the knob and put some liquid paper in
the scratch so it will help you count the 2 turns
laid back
Bikes: Rans Xstream, Bike Friday Pocket Rocket
If you are using a spare wheel, do you change out the cassette too, or do you get a spare cassette?
