Wheelbuilding: Interlace oval/bladed spokes?
Would you interlace the leading spokes on a 3x wheel using oval or bladed spokes?
I'm using Wheelsmith AE15 spokes which have an oval cross section. I'm planning on interlacing the leading spokes once as they cross the last spoke on the way to the rim as I would using round spokes. Let me know if this is ok.
Would you do anything else different when wheelbuilding with oval spokes?
Thanks!
Thanks!
If you mean cross the spokes, that's fine.
When you turn the spoke nipple on an aero/bladed spoke, make sure you're not winding up the spoke (twisting it). Turn the nipple so it turns the amount you want *on the spoke*, then untwist the spoke as necessary. You may turn the spoke nipple 1 turn to get 1/4 turn on the spoke, then turn the nipple back 3/4 turn to unwind the spoke. I lightly hold the spoke with my other hand while I turn the spoke nipple. This way I can feel the wind up as it happens, and the un-wind as it happens.
Check your tension as the numbers are different from round spokes.
Have fun building the wheel,
cdr
cdr
Quoted: 1858 Post(s)
Liked 664 Times
My builder made me a set of wheels with Sapim CXrays, and yes they are interlaced.
Bill
Bikes: Specialized Globe Sport, Specialized Stumpjumper FSR Pro
If I was doing it I'd switch to double butted round.
Aluminium Crusader :-)
yep, nothing wrong with it. I have some of these with 2-crossed oval DT Aero Speed spokes (1.2mm x 2.3mm). I also have some Tokens with bladed spokes, and the rear is 2-cross.
Bikes: Iron Monkey: a junkyard steel 26" slick-tired city bike. Grey Fox: A Trek 7x00 frame, painted, with everything built, from spokes up. Jet Jaguar: A 92 Cannondale R900 frame, powder coated matte black with red and aluminum highlights.
Why are you using round and oval spokes?
messenger
Bikes: pinarellos and a colnago
use double butted dt ss round--- never oval anything; never colored,,,never---- creaky, breaky, sucky---- cant true on the fly--- on and on-- bad weather,hard riding--- onand on....... anodized nothing--- bright shiney smiley dbswiss!!!! boys!
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
From what I hear, Aerolites (oval) are stronger and easier to work with than Revolutions (double butted) and weigh about the same. So there.
Now go build your wheels laced like normal and enjoy them!
It's like riding a bicycle
