bullhorn brakes
Bikes: 08 Schwinn Madison
bullhorn brakes
I am planning on switching out the handlebars on my 08 Schwinn Madison with bullhorns but I'm unsure of what brakes to use. Heres the bar I'm thinking of getting
https://www.pricepoint.com/detail/174...llhorn-Bar.htm
These brake levers fit right in the end of the bar right? Also, is the installation fairly easy?
https://www.pricepoint.com/detail.htm...8&hprice=24.98
Just want to make sure before I order them.
Thanks,
Peter
Thanks,
Peter
yes the brake levers will work with your bars, so go ahead and order them .
Bikes: Iron Monkey: a junkyard steel 26" slick-tired city bike. Grey Fox: A Trek 7x00 frame, painted, with everything built, from spokes up. Jet Jaguar: A 92 Cannondale R900 frame, powder coated matte black with red and aluminum highlights.
I like putting "cyclocross" levers on my bullhorns. It moves the levers in a little closer and leaves the ends of the bars open for shifters. They also usually cost a little less.
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
This would be a good idea if the OP plans on doing most riding on the flats, otherwise the bullhorn/TT levers would probably be preferable. The Madison is a single-speed/fixed-gear, so no need to worry about shifters.
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
I think that is a great idea... except I would do it differently... put the drop-bar levers on the bends of the bars (where the bars turn from forward facing to lateral facing) then put the cyclocross interrupter style brakes out at the end... this will be extra coon because the cables will stick waaa-aaay out like old style hi-wire cable routing. You can be like all the heroes - Grege Lemonde and Eddye Merycxe.
thanks
Thanks for the help I will be purchasing the bull horns soon and yeah it is a single so no need to worry about shifters. I actually just flipped it to a fixie and I am LOVING it, I never thought I would.
Thanks again
Thanks again
Steel snob by accident
Bikes: Masi steel cross, Torelli steel roadie, Brew steel bmx
if he usually runs it fixed and is good with foot braking, the he could put the levers on the flats so they're out of the way when he's hammering it with his hands on the 'horns'
Oh, I see.
The lever mounts are closer, but the levers themselves are in the same place as if they were mounted on the ends.
I'm actually going to cut down my bars a bit anyway — the stretch is farther than is comfortable.
