advise bar "extenders"
Bikes: Specialized Roubaix Comp, Specialized Rockhopper Expert, Specialized Sirrus Comp
Hi, I am riding daily on my Trek Soho 2 - which is a nice bike and one should wish nothing more, however... I like to add two extra handgrips to my "arc" - shaped steer. I will not use them on the outer left/right side because then they will point awkwardly in the "wrong" direction. I thought it would be good to attach these extra grips a bit more close to the middle of the steer pointing upwards and a bit forward. This will give me some extra hand rests on the steer. Maybe this will help to overcome some of the numbness of the right hand after an hour ride. Any tips on this sort of extra grips?
Bike ≠ Car ≠ Ped.
Sure, put 'em anywhere you want. You could start experiencing shoulder pain, though, by having a hand position too far inboard. Other options would be bullhorn-type bars or any other handlebar (I'm pondering some swept-back bars like the On One Mary for my flatbar bikes).
Bar extenders
Thank you for your reaction -
Bike ≠ Car ≠ Ped.
No problem.
The funny thing about handlebars is, no matter what configuration somebody thinks of, chances are somebody else has done it already. Dig around enough and you can find commercially-available parts for building whatever you want.
I did not yet find extenders that you can attach right away on the right spot. The ones I found need to be slided up to their position starting at the end of the left/right of the steer. Which makes it necessary to dismantel the gears etc.
But I keep searching - it should be available somewhere I am sure.
Bike ≠ Car ≠ Ped.
Don't worry much about removing stuff from the bars. Although it's time consuming, it's pretty simple.
Bar ends with hinged clamps are indeed hard to find.
Even if I can remove the stuff left and right, I will not be able to slide the ends to the position I need them to be, as the steer consists of an arced front tube that is permanently attached to an arced smaller tube that is attached to the stem. The tubes are attached almost right besides the handles and the extenders should be placed more to the middle of the steer. So, if a hinged version is not available, I may need to buy another steer after all.
Bike ≠ Car ≠ Ped.
Hmm...
I didn't see any at bikepartsplace.com, but they don't have all the brands that I've seen in stores, either.
There are tons of bar ends at https://www.bikeparts.com/search_resu...lcategory=1341 -- but I don't see any hinged versions there.
Any pics of your handlebars? All the pictures I'm finding of the Soho 2.0 are directly from the side as Trek photographed them, and I can't see anything unusual about their bars.
Hi again, the bar looks like the one you'll find in this other thread:
https://www.bikeforums.net/general-cycling-discussion/447256-aero-bars-hybrid-trekking-bars.html
The arced one, not the butterfly; compared with that steer. Mine is a different in that the smaller tube is bigger and attached to the front bar a bit more to the ends,
Actually, after work I went to another bike dealer who's into Specialized/Cannondale - He handed over some grips with "ergonomic plateaus" to be more comfortable for your hand - I can check them and if they don't work I can return them. They also have a small metal end grip, that may overcome to slip away with your hands, but in themselfs offer another extra grip. Hope my English makes sense...
Bike ≠ Car ≠ Ped.
https://www.bikeforums.net/showthread.php?t=447256
https://www.ergon-bike.com/en/grips/i...hbrc3dl2f3mrt4
I've got a pair, and they really work well. It took some time to get them adjusted just right, but once I got them set, I wouldn't trade them for any other grips. I'd recommend any grip in this style for flat handlebars.
Yeah! they look the same as the ergon grips!! - I mounted them this evening; maybe it'll work out nicely... tomorrow morning test drive - I'll take a tool with me to adjust along the way. ;-))
Bikes: Lapierre CF Sensium 400. Jamis Ventura Sport. Trek 800. Giant Cypress.
I once wanted a special tray for holding some of my percussion shakers and other tools when I was playing percussion for a group. I couldn’t find “exactly” what I wanted so I contacted a machinist and he and I drew what I wanted. It took a few weeks but I got just the tray I wanted and it attached just the way I wanted. It might cost a bit but never overlook the work a good machine shop can do. They could design some that clamp on much like a clamp on bar mount.
Hi Robert, I may eventually do that. The ergon grips still need a test ride though, because of the s... weather I climbed on my home trainer... which appears to give me another problem; a numb butt(!), but I managed to train for more than an hour. Tomorrow I'll ride on the bike when it's better weather...
Hey, these Ergon Grips do the trick! - No numb hands anymore ;-)
