Hub rebuild question
Bikes: '91 Diamond Back Sorrento, '78 Fuji Gran Tourer
My 1991 Diamondback's front wheel has a Shimano Exage hub that is possibly in need of a rebuild. I imagine this is a fairly inexpensive hub. Any way, it makes noise when riding and you can feel the friction when you spin the wheel on the bike. If it does need a rebuild and I can get the bearings and cones from a bike shop is this worth the rebuild?
Thanx for your reply
kg
kg
Spin Forest! Spin!
Bikes: I used to have many. And I Will again.
Quoted: 7 Post(s)
Liked 11 Times
Disassemble and inspect the cones and cups. If the cones are pitted but the cups are smooth, then the hub is rebuildable with a replacement set of cones. But if the cups are shot, it's time for a new hub. Shimano doesn't market replacement cups for their low-end model hubs, if any.
Bearings are 3/16" Grade 25. Bag of 100 should be $4. Cones, under $10 for a pair.
A new hub can be found for as low as $10 (deore LX). But you'll need to relace the wheel and true it. Unless you know how and have a truing stand, expect to pay $.
