skippig gears
skippig gears
i have an raleigh at 30 mountain bike with 27 gears problem is it keeps skipping or trying to change gear when in the highest gear bike is only 4 months old no damage adjusted everthing possible on the derailler was wondering if it could be the inside of the cassette which has teeth on it that grips the wheel when you pedal and makes the clicking nnoise when you pedal backward all help appreciated
POWERCRANK addict
Welcome - do a search in the mechanics forum or have a look at
https://www.sheldonbrown.com/
https://www.parktool.com/repair/
shameless POWERCRANK plug
Recommended reading for all cyclists - Cyclecraft - Effective Cycling
Condor Cycles - quite possibly the best bike shop in London
Don't run red lights, wear a helmet, use hand signals, get some cycle lights(front and rear) and, FFS, don't run red lights!
