tire direction
tire direction
I want to make sure I got my tires on the right way the tires have arrows {------rear front ------} does the front point to the front when it is on the top or the bottom or the tire if that makes any sense? thanks
Bikes: '03 Fuji Roubaix Pro; '03 KleinGi Attitude; '06 Soma Rush; '04 Surly Cross-Check; '06 Soma Rush; '07 Scott CR1 / Chorus
Originally Posted by tFUnK
direction of rotation... so top
I couldn't car less.
Bikes: Ritchey P-series prototype, Diamondback, Nishiki Triathelon Pro.
Tread chevrons pointed the same direction the bike is. >>
I see many mtb with them reversed.
The rear is sometimes reversed if worn and downhillin'
2-Cyl, 1/2 HP @ 90 RPM
Bikes: 04' Specialized Hardrock Sport, 03' Giant OCR2 (SOLD!), 04' Litespeed Firenze, 04' Giant OCR Touring, 07' Specialized Langster Comp
My set of specialized hemisphere's have a thread pattern that seems to channel water away from the contact patch better if aligned properly.
Then again I've seen tires that are nearly slick that are directional too...
