uncommonly fast decents?
OK, strange bike behavior: it doesn't climb well or accelerate well, and descends faster than it probably should. It's a nice road bike that usually rides wonderfully, but just has been acting weird the past few weeks.
(When I was younger I had a mountain bike that behaved like this but to an extreme, so that descents were terrifying. I never did find out what was wrong with it, because I grew out of it so quickly anyway.)
What do you suppose the problem is, do I just need to make a trip to the LBS for a tune-up?
and the question is? uncommonly fast decents? compared to what and what do you consider fast? the up hill and accelerating is the engine for sure.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
Gaeilgeoir
Bikes: 2003 Giant Iguana (ONCE yellow), '86 Team Fuji (Blue/Yellow), '87 Schwinn Le Tour (Frost White)
is this a riddle?
moron
Oohhh, busted Local Gravity Modulator. Too bad - gonna be expensive to fix. It's happened to your bikes before, eh? I'd get to the doctor - get a radiation emission eval. Of course, that could get expensive, too....
ummmmmmmm i'm 125 pounds, i don't think my weight is the issue. smartass. but seriously. doesn't accelerate well, and barrels down gradual slopes.
if anyone's got a constructive response, i'd like to hear it!
holyrollin'
It's not as clear a problem as it might be. The whole point is to make the bicycle the best machine it can be: less friction, less drag, faster speed with less energy spent...and you are complaining that essentially the bike is working too well.
Is it that your brakes don't slow the bike enough going downhill?
my brakes seem fine, actually. anyway it's not just fast descents though, it's also that riding around on inclines or level ground is like dragging around a tank. been going on for about two weeks... never had issues with it before that. no, i did not gain weight.
holyrollin'
Okay, thank you for the clarification. Do you maintain the same tire pressure as usual? Is it possible you have a brake dragging on the rim without it being noticeable? I've had that happen when my wheel went out-of-true and started rubbing the brake.
I would suggest the tires first. I understand some people find it funny to let a little air out of your tires when you're not looking, and then later they'll make jokes about your weight.
Bikes: Trek 1000, two mtbs and working on a fixie for commuting.
Bikes: Nishiki Backroad;: fuji mountain bike
pardon me for showing my dumb but does it have disc brakes if so check that part to see if the friction is to tight on the disc if it has regular brakes then check the wheel for wobble and placing undue pressure on the wheel
just some thoughts
just some thoughts
moron
Are you indeed traveling faster (per your computer) on downhills than you did previously, or does it simply seem scary fast because the bike's handling has become sketchy? If the latter, or if you're not sure, I'd have the LBS give it a once-over, looking at wheel bearings, etc which might also make it feel sluggish on the flats - or worst case scenario, an injured frame issue. If the former, I stand by my gravity modulator postulate.
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
BBZZZZZZZZZZTTTT!!!!!
Oh! Sorry, but no.
Gravity accelerates things towards earth as a rate of 32 ft/s/s - every second that passes while an object is falling it gains another 32 ft/s of velocity...
But this is only really true in a vacuum with no other objects exerting force on the falling body. If you drop a feather and a bowling ball at the same time which will hit the ground first? In real life it is the bowling ball (aerodynamic resistance will play a large role in slowing the feather), but in a total vaccum they would hit the ground at the same time (in a vacuum no air = no aerodynamic resistance). If two riders are of approximately the same dimension but one is considerably heavier (like one rider has lead weights strapped all over his body) the heavier rider will be able to coast downhill faster.
The Improbable Bulk
Bikes: Many
Quoted: 5 Post(s)
Liked 7 Times
If you are truly going down hill faster, and not just that it feels faster (as someone has asked) then I suspect that weight is somehow the issue.
Is there a chance that someone is playing a joke on you?
Is the bike heavier when you lift it?
Check your tires and frame tubes to see if anything has been added to make them heavier...
Did you just switch to tubes with slime in them to prevent flats?
Did anything change a couple of weeks ago? New tires/wheels etc?
Slow Ride Cyclists of NEPA
People do not seem to realize that their opinion of the world is also a confession of character.
- Ralph Waldo Emerson
on your left.
Bikes: Scott SUB 30, Backtrax MTB
probably a tire issue. but, it's possible that maybe your bottom bracket is not working correctly, which could mean when you pedal and you're not freewheeling it feels sluggish. and when you are freewheeling and the bottom bracket is not moving, you feel faster.
did anybody follow that?
Great State of Varmint
Liked 15 Times
One is mixing, or missing, air-drag into the gravity formulae. Personally I prefer 16T2. But unless one is planning to drop the bicycle off a tall building, I don't think it will apply.
