Double crank with triple shifters and longcage?
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
Can I switch out a triple for a double crankset without switching out the shifters and long cage derailleur? I see Ultegra doubles on Icycleusa for under a hundred bucks. Having a hard time finding triples (105)for under $200.
Will it work? I have DA on another bike so not looking for a highend rig, just my riding/beater bike. 15,000 miles on the Bonti crankset so it's pretty much junk. I can live without the triple.
Quoted: 38 Post(s)
Liked 11 Times
I won't tell the shifter/derailler that grannies missing.You'll probably need to change the BB to a shorter one for the double so your chainline isn't off.
If the crankarms are OK and you can live with it,you can buy new chainrings much cheaper than $100.You probably only need the outer 2,I wouldn't think grannies worn too bad unless you do loaded touring.
Quoted: 2026 Post(s)
Liked 1,096 Times
Depending on your shifter model, many were made to handle either a double or a triple. All 9-speed 105 and Ultegras were as well as 10-speed 105. All Campy Ergos are double/triple compatible.
Even if you have a triple-specific shifter you can use it on a double by adjusting the inner limit screw appropriately.
The rear derailleur is completly indifferent to what's up front as long as it has the needed chain wrap capacity. Your long cage will be fine, it will just have capacity you don't take advantage of.
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
Really? Try eBay. They're pretty common, and often sold with BB. Any Shimano triple road crank will fit, and work. You should be able to score something for $30-100.
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
Thanks for the time and info guys, looking good and in my favor!
TW, brifters ar 105 and der''s are Ultegra. Crank is Bontrager so I plan on swapping the BB too!
