Go Back  Bike Forums > Bike Forums > Training & Nutrition
burning thighs during sprints?
Training & Nutrition Learn how to develop a training schedule that's good for you. What should you eat and drink on your ride? Learn everything you need to know about training and nutrition here.
Old 09-25-08 | 05:04 AM
Is it normal to have a burning sensation in my thighs DURING a sprint?
In my school athletics team I did 100 metre sprints and my thighs don't hurt at all during or after the sprint. I also wear Skins half tights which help compress the thigh muscle areas. I wear the half tights under my cycling shorts so could lactic acid build up be ruled out? (https://www.skins.net/au/en/HowSkinsWork)
How could I sprint for longer? Or do I need to live through the pain?
thanks.
Chaderotti is offline
Reply
Old 09-25-08 | 06:41 AM
127.0.0.1's Avatar
50000 Guatts of power
it's normal
HTFU and keep doing it
it will sort itself out
127.0.0.1 is offline
Reply
Old 09-25-08 | 07:23 AM
AnthonyG's Avatar
It is normal to get some kind of lactic acid burn in your muscles in a sprint. I don't know much about the Skins tights but i find it hard to believe that they could totally eliminate lactic acid muscle burn. Now if that lactic acid burn is too much then a likely candidate is a lack of minerals. Magnesium and Potassium would be up there on top of the list.
Anthony
AnthonyG is offline
Reply
Old 09-25-08 | 08:13 AM
127.0.0.1's Avatar
Anthony
all good advice
I wouldn't worry about anything unless you cramp and have to stop. Then you may investigate minerals and electrolytes. But if you snap out of it and can keep riding, then the pain is just something you need more of. pain is weakness leaving the body if you don't seize up and cramp.
try Spinervals 3.0. It has some 1 minute intervals where you go 100% a lot. and true 100% at one minute, and 5 in a row like that, you will feel pain everywhere and want to cry. but then next time you are on the bike you just float by all the posers
who don't crush themselves as hard....
Reply
Old 09-30-08 | 11:35 AM
127.0.0.1's Avatar
Originally Posted by Shake'n'Bake
The goal isn't to learn to endure the pain, simply for the sake of proving how tough you are, the goal is to reduce the pain as much as possible so that your body can focus on the task at hand, making the bike go as fast as possible.
incorrect.
to get better you must endure discomfort. a lot of discomfort. if not, then you are NOT doing it right
to go as fast as possible you better bet your a** it hurts.
so back to what I said...htfu and go harder longer the next time.
your face, your teeth, your throat, lung, your ears, your back and butt and legs and feet should all feel uncomfortable and your feet should be about to pop off both pedals. then you are 'sprinting' correctly and are really riding at max.
Reply
Old 09-30-08 | 12:24 PM
127.0.0.1's Avatar
he asked is it normal for my thighs to burn during sprinting
yes it is.
Reply
Old 09-30-08 | 12:31 PM
Administrator
20 Anniversary
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
It's not all lactic acid either. You are calling on muscle fibers in your quads that aren't use to the hard work. Intervals and hard training help.
StanSeven is offline
Reply
Old 09-30-08 | 12:57 PM
127.0.0.1's Avatar
Perhaps you didn't read my previous post closely enough. Sprints will not produce a large amount of lactic acid, they are simply too short. If what you are doing produces lactic acid, then it isn't a sprint.
Trust me on this one, I've sprinted against, (and lost to) some of the greatest sprinters of the 80's hundreds of times. I know what a sprint feels like, and I know the biomechanics behind it.
sounds like you don't ride hard enough.
simple
ride friggin hard, basically always, and take yer rest days and ez spins to recover
ha cripes I sound like the reincarnation of ryanf I better stfu myself
Reply
Old 09-30-08 | 11:43 PM
so basically, on days when I do sprints... I have to push myself soo hard I'm about to cry??
Reply
Old 10-01-08 | 08:10 AM
Creakyknees's Avatar
ride lots be safe
Dooods.... this is such an obvious troll. Suckahs.
Creakyknees is offline
Reply
Old 10-02-08 | 04:52 AM
OR a newbie who doesn't know if this sort of pain is 'good'
Reply
Old 10-02-08 | 06:37 AM
127.0.0.1's Avatar
dude the pain is OK. after a long ride of hammering along, and the final sprint, your legs
are probably full of acid and just below cramp threshold, and sprinting will hurt for sure.
but you will know if the pain is something to worry about if you start to slow down
and not want to ride.
interval training can blow your legs up and then the next day, or 2 days after, your legs might
hurt for the first 10 miles and you have to just warmup and push though that. if you hammer
though the pain it should go away and then you can keep hammering. if not, then you may be
overtrained and you need to do easy spins for one more day
sprint enough and do leg work like squats and eventually you legs will not hurt in sprints, they
will be strong enough that the only limit is not leg pain, but breathing. your lungs really should
be the only thing that burns when your legs are powerful and you sprint. the legs are not the
limit at this point it is aerobic capacity. squats and iso squats can help
anyhow......don't worry about it...harden up and hammer ! if your joints make noises and you
start to walk with a limp then something is wrong, prob need to back off a bit for a week.
Reply
Old 10-02-08 | 03:04 PM
Carbonfiberboy's Avatar
just another gosling
Titanium Club Membership
15 Anniversary
I dunno. I'm a pretty good sprinter on the bike. Guys 20 years younger than I with legs like "real riders" can beat me, but that's about it. My legs don't burn. When I run out of sprint, they just stop working. That's the reason that you have to know your point intimately for every degree of exhaustion. You have to know where to start or they'll go by you at the line. You all know that. It's not the pain that stops you. If you're really going, you don't feel anything except the animal hunger for that line or sign or whatever. It's true that you do have to pay attention. You don't want to hit anything or come totally unglued and come off the bike, but other than that it's just a blast.
So, why does Chad hurt? He's done a lot of track sprints, so he knows what that's like. I wonder if he's ever run 10,000 meters, rested for 2 minutes, and then sprinted 100 meters? Now that's pain. It's just biking the distance. More lactic acid clearing intervals, like pyramid intervals or 1 minute max, one minute easy, that kind of thing. So that's what I'd say. Also try sets of 45 second uphill "sprints," which aren't real sprints, just max efforts, with 5 minutes between them.
It partly depends on whether he's trying to become an all-round rider, or trying to specialize. If he wants to be an all-rounder, than he's got to work on converting some fast twitch into type II. I think really long climbs, like 30 minutes at LT, are good for that. After the first few minutes, your fast twitch are cooked. Maybe what's going on is that his few slow twitch fibers are getting overcooked. That would hurt. Someone else perhaps can speak to the training necessary to specialize in the sprint.
Carbonfiberboy is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
