Cantilever Brakes - Cable Question
Folsom Prison Blues
Bikes: '04 Trek 5200, '73 Raleigh Grand Sport "Fixie" & '94 Specialized Rock Hopper Comp MTB
I have late 80's MTB with Shimano DX cantilever brakes in which the main brake cable connects to one of the brake arms and the other brake arm is connected to the main cable with a short cable (barrel end x compression clamp).
After many attempts and once by LBS I cannot seem to ever make both cantilevered brake arms move in a mirrored synchronized manner. To resolve this I was thinking of installing a single cable both cantilevered brake arms to form the upside down "V" and then connect the upside down "V" to the main brake cable with a cable connecter.
Now for my questions.... do you recommend doing this? Or am I just not setting up the existing system properly?
The brake cable moves freely within the little housing there is. I hope you were able to follow my description.
PS Yesterday was the first time I was able to ride outdoors since I broke my collar bone 6 weeks ago (went down while riding in the rain). My shoulder is a little sore today but it was nice to get off the stationary cycle.
legalize bikes
Bikes: too damn many
your brakes might have a small adjusting screw on one of the cantilever arms. this screw adjusts the return spring tension. fiddling with it will probably get your brakes working the way you want them to. if they dont have the small screw than the brakes are probably low end so you might want to upgrade.
Perineal Pressurized
https://www.sheldonbrown.com/brakes/index.html
And read through the Barnett manuals, found at the top of this forum. It might be a simple as having the wrong size straddle wire.
https://harriscyclery.net/site/page.c...9&Category=450
I couldn't car less.
Bikes: Ritchey P-series prototype, Diamondback, Nishiki Triathelon Pro.
Also check that the bosses ( the frame anchors ) have the pins in the same hole (there are 3).
Both SHOULD be in the same position.
Pull the brakes apart ( grease them ) check that both
internal pin anchors for the springs are in the same hole,
Shimano has 2 internal pin positions.
legalize_it got it probably, I set them up as close as I can then adjust the screw.
Good luck!
Good luck!
Quoted: 12192 Post(s)
Liked 1,496 Times
Hi,
I found a straddle rod to be helpful. The knurled knob just underneath the yoke adjusts the legth of each rod seperately. Nice to eliminate some of the cable stretch
as well.
https://cgi.ebay.com/ws/eBayISAPI.dll...category=27949
as well.
Quoted: 1572 Post(s)
Liked 643 Times
If your brake arms aren't working in a synchronized manner, most likely your problem is return spring tension. Each arm has it's own return spring and, if the tension on them isn't the same, only the arm with the stronger spring will return. Most Shimano cantys of that era have a little screw on one of the arms. Adjusting that screw inward or outward will adjust the tension on that spring. Usually if you fiddle with it enough you can get the two arms to balance.
If that doesn't work, look to where the arms mount on the fork or stay. Most canty mounting studs of that era had a series of three holes in them for the end of the canty spring to poke into. By using one of the alternate holes on one arm or the other, you can affect the balbnce of the springs.
