Trek 1.2/1.5?
Ride that pony.
Bikes: Schwinn Skyliner
Trek 1.2/1.5?
I'm in the market of upgrading to my first road bike. I test rode a few Trek's, a couple Giants, and was more impressed with the Trek 1.2 (based on price - college grad, c'mon). I was wondering if anyone else had any opinions on it and could help me out with my purchasing decision.
Ride that pony.
Well I did try a Madone and that would be the best case, but I doubt anyone would want to part with one any time soon and for the price I want.
Bikes: cannondale caad 8 custom
1,5 uses better aluminum in the frame in addition to better wheels and mostly tiagra instead of sora
Just a girl on a bike...
Being a poor college student I dropped the highest amount I could afford to spend on a 1.2 WSD. I love it! Its a good bike and probably all you need unless you intend to start racing. I havn't had any problems with it and I really enjoy riding it so I would say if its in your budget and you feel comfortable on it then its a good option. That being said if you've got the money and you find the 1.5 comfortable then you might as well start higher.
Obsessed
Bikes: 08 Giant OCR 1
I wouldn't go brand new unless you are getting a free year of tune-ups, which is really nice. When you brand new, you are essentially getting ripped off, because you have to spend tons of money in order to get a bike with a decent set of components. Any way you go however, you will love your bike and I think thats what really matters.
Unless you're 100% sure about sizing, i'd say to buy new from a reputable shop to ensure you're getting sized correctly. A bike that fits you properly will mean much more than the overall component mix.
Having said that, i'd perhaps consider avoiding the lower end Trek bikes, there really isn't anything all that special about them (conversely, they're not bad bikes either). They use a Chinese-built frame, and entry-level components, you may get better value from another brand, and I wouldn't expect much of a difference as far as the frame or components go. I would also suggest checking out entry level offerings from Giant, Specialized, Felt, and Cannondale (Cannondale's entry-level might be a bit pricier but their CAAD9 frame is top-notch, made in the USA, and only a few years ago was the frame used on their high-end bikes).
To summarize:
1. Buy based on fit
2. As long as the brand is reputable, don't worry as much about the brand. In the entry-level you'll mostly find Chinese or Taiwanese made frames (Taiwanese is usually better), and Sora/Tiagra components. If you can get a bike with Tiagra shifters, go for it, the Tiagra shifters are functionally similar to the rest of Shimano's lineup, while Sora has the shifter button in a different location.
3. Buy based on fit
Good luck on your search. There's nothing wrong with the Trek's, but i'd check out other brands as well to make sure you're getting the best-fitting bike.
Once you're comfortable on the bike, and think you want to upgrade, then consider selling off the current bike and buying something used. By then you should have a good idea of what type of geometry suits and what doesn't and can buy based on spec.
To summarize:
1. Buy based on fit
3. Buy based on fit
To summarize:
1. Buy based on fit
3. Buy based on fit
To summarize:
1. Buy based on fit
3. Buy based on fit
Ride that pony.
The whole reason I'm buying new is because the dealer is that good. I have never been properly sized for a bike before, and two of their employees worked to find the EXACT bike, looked at my geometry and compared it to the right bike. They let me test ride it around the lot, put the bike on a trainer and let me get it to good speeds, and are able to give me free tune-ups for a year. Plus it's kinda nice to have something new once in a while. Am I still nuts?
Sounds like you've made up your mind already. So I'm not sure why you're asking for opinions here.
If you do any comparison shopping at all, comparing specs and features, you'll see right away that Trek's are overpriced and underequipped. You can get a much better deal on practically any other brand of bike.
