Braze on Removal
Braze on Removal
I have an early Masa road frame. I want to remove the cable stops and down tube shifter mounts. Whats the best way? Grind them off ? Heat them and remove ? Any tech on this ?
Bikes: 2005 S-Works SR Equipped,1978 Tom Ritchie Road bike, Kuwahara Tandem
I removed some braze on items on my tandem frame and with a little heat they just came right off. Sanding the tubes after made it look like it was not even there.
Randomhead
Liked 3,698 Times
is that a Masi? If so, you don't want to mess with it.
I would never sweat off a fitting, grind it off carefully.
