Seapost Noise Specialized Enduro
Old 10-10-08, 01:51 AM
Everest's Avatar
Bikes: Lemond Alpe d'Huez, 03 Gary Fisher Tassjara, Quattro Assi Scandium
So my 2005 Specialized Enduro Comp is making a sqeaking noise. I have narrowed it down to the saddle or seatpost collar (it's not the saddle as I just switched it out for one I know is good. Anyway from what I have read on MTBR.com both of these parts are problem areas on this bike. Is there anything I can do to fix this should I try to grease the collar or something? Eventually I will probably just replace both parts as deals come along but am looking for a temporary solution till then. Also with the seapost collar how do I know what size I need? The bike has a 30.9 Seatpost. Thanks for any and all help/suggestions.
Road: Quattro Assi Scandium w/ SRAM Rival and Rolf Echelon's
Mountain: 2005 Specialized Enduro Comp
2003 Gary Fisher Tassajara
Everest is offline
Old 10-10-08, 02:08 PM
z415's Avatar
Bikes: Trek 1000, two mtbs and working on a fixie for commuting.
I had a similar problem on and much cheaper bike and a light layer of grease everywhere fixed it.
z415 is offline
Old 10-10-08, 02:19 PM
I spit hot fire
Diggidy_Dylan's Avatar
Bikes: IRO Jamie Roy--Stolen, Specialized SJ, ****-tons of beaters
I'd start by making sure the seat binder bolt(s) are tight. Those are the ones that hold the seat to the post. Make sure they're hecka tight. If that doesn't work a little bit of grease between any parts that contact a different part.
As for replacing, Thomson seatpost's are the best.
Thomson usually does contract machining for companies like Boeing and Ford.
Diggidy_Dylan is offline
Old 10-10-08, 02:39 PM
Map maker
cbchess's Avatar
Bikes: Ventana El Ciclon, Walt Works 29er, Specialized Enduro (fixed up for my son).
I have a 2003 Enduro that had this problem- grease the collar (and under the collar) and the collar bolt and grease the seatpost. I also had trouble with the seatpost slipping no matter how tight I cranked the collar and bolt down.
I switched to a Thomson post and a Salsa collar and never had any trouble after that!
cbchess is offline
Old 10-10-08, 03:04 PM
Everest's Avatar
Yeah I have Thomson posts on all my other bikes so that is most likely what will be going once I get the cash. My main question is what size collar I should order when I get a replacement. Salsa Fliplocks come in 28.6, 30.0, 30.6, 32.0, 35.0 or 36.4mm sizes and Hope Collars come in 28.6, 31.08, 34.9, and 36.4.
Everest is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
