Rims and Brake wear
Just give'er.
Bikes: 04 Scrap
Rims and Brake wear
Hey
My bike had crappy brakes and then one day, all this black rubber started smearing onto my rims. I got new pads (Eagle 2's) and the bike person told me to clean awaay the rubber smudges on my bike using steel wool. Does that work, or would that take the rust proof part off the rim and make it vulnerable to rust.Should I use the steel wool, or should I use something else to clean it off, without destroying the rim. Also, I'm presuming that it would scratch the rim alot as well. The salesman said that if I didn't take the rubber smudge off, a lot of noise would result, as I already had alot of squeaking going on, when I braked. By the way, I have v brakes.... What should I do??
DEADBEEF
From: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Do you have ceramic rims? There's likely no rust-proofing on your rims as your rims are probably made of aluminum. However, if you have ceramic rims then it might not be a good idea to hit it with the steel-wool.
1999 K2 OzM
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
1999 K2 OzM
2001 Aegis Aro Svelte"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
Just give'er.
Bikes: 04 Scrap
I dont know, I think I got alloy rims (i have cheap bike), but I don't know what type of allow they are. Well anyways, I really need to know this because, I dont want to destroy my rims. Scratches are fine....but rusty rims aren't. Any body know how to clean off the rubber residue from crappy pads? Anyone?!
Originally Posted by Maelstrom
I thought alloy was steel?
So the term "alloy" is just a very general (but popular) term for metals mixed together for form one metal, per say. The term is also often wrongly used in automotive contexts, i.e. I've seen car dealership ads claiming their car has alloy rims, but turn out to be just chrome plated steel, where in this case it would apply to aluminum alloy.
Less confused now? I'm sure you have aluminum rims, they are aluminum on top, underneath, and all around...
Jessica
Bikes: Lots
I buy those green Scotchbrite pads used for cleaning pots and pans. I shove one between the brake pad and the rim, then ride down the street and back for about a minute. Then swap it over to the other side.
Cleans up right up!
L8R
Cleans up right up!
L8R
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
Why would the bike shop person suggest steel wool? That's ridiculous!
It will scratch your rims badly. Don't use steel wool! Use rubbing alcohol instead. I used it on my rims and it works great. There's a topic about rim cleaning further down the MTB forum list. Here's a link: Cleaning the rims
Just give'er.
Bikes: 04 Scrap
By the way...this is off topic, but how come when I try to choose an avatar, it is either ALWAYS "Do not choose an avatar" or "Choose a custom Avatar"? I WANT TO USE AN AVATAR THAT COMES WITH SITE!
