Sealed Campy hub bearings replaceable?
slow up hills
Bikes: Giant TCR, Redline CX, Ritchey Breakaway, Spec S-works epic
I have a 9spd Veloce rear hub that is a little rough. I took it apart today to regrease/repack it....only to find that the bearings are sealed. Has anyone successfully (and economically) replaced their hub bearings in this type of hub?
It seems like I might be able to press the bearings out and press new ones in, but am not sure it's worth the effort. The rim is an open pro, and the spokes are of thick gauge while the nipples are red anodized (sweet looking). I'd rather not relace the wheel, but if I have to I will. Also, if I do have to relace it, can I re-use the hub body and put it onto something else, or are they campy specific?
thanks for the help in advance
Quoted: 303 Post(s)
Liked 136 Times
Bearings should be 'standard' ie available from any bearing dealer net or walkin worth the name.
Removal is a matter of appropriate slow steady force applied from the opposite side of the bearing
Depends on your access but the hub has to be hollow. Even with locktite on the bearing it should
extrude out with some gentle persuasion. Bearing will have some cryptic numbers on the seal, take the
intact bearing to bearing store or cross ref with google. Doubt they will cost more than $2-4 each. 3/8" all thread, a couple of nuts and washers will allow you to press in the new bearings. Campy hubs highly likely to be Campy splined.
It's possible that the bearings will be upgradeable as well. Campy has extensive spare parts lists and you can check between parts to see what is compatible. I don't know the various bearing diameters off hand but you can check here:
https://www.campagnolo.com/jsp/en/doc/doccatid_3.jsp
A sweet upgrade would be the ceramic upgrade (CULT bearings) if they fit. CULT uses super hardened stainless races so they will last longer than the standard ceramic bearing units out there.
cdr
cdr
Quoted: 2026 Post(s)
Liked 1,096 Times
I know Campy's Chorus and Record hubs have cup-and-cone bearings and 10-speed Centaur and below hubs have (had?) sealed bearings but I wasn't aware 9-speed Veloce hubs had sealed bearings.
Interestingly, Campy seems to be getting out of the hub business altogether. Their website now lists only Record hubs as a separarate component. Chorus lists the Record hub and Centaur and Veloce groups include no hubs whatsoever. I guess Campy wants to sell complete wheels, not hubs.
Quoted: 3375 Post(s)
Liked 5,513 Times
Antiquated cone-and-ball on the high-end stuff.
That is why I went with Centaur hubs on the Litespeed I built last spring.
In 1997 I had ColoCyclist build a new pair of wheels for me with Phil Wood sealed-bearing hubs. The rims have been replaced several times since then. I have never touched the hubs. They are still as solid and silky-smooth as the day I received them. Why the hell would I want to go back to the obsolete design. I have better things to do with my time than fuss with hub bearings.
slow up hills
Gotta love it; State-of-the-art sealed bearings on the low-end stuff;
slow up hills
cdr
cdr
thanks again
Liked 5,513 Times
"sealed bearing" is a bit of a misnomer -- it just means you can't service it. Maybe the higher quality of your Phil Wood bearings is the reason they're so smooth. The lower quality bearings on my veloce hubs haven't stood up to the cyclocross all that well. If they were "antiquated" I could just repack them and have them nearly as good as new. As it is, they're toast and I'm left trying to figure our what other bearings are compatible and just how exactly to R&R them.
Liked 5,513 Times
CDR, thanks for the help. It looks like my winners are "FH-MI113". Unfortunately google doesn't know anything about these. Any suggestions for finding compatible "upgraded" bearings? Should I just pop them out and look for letters/numbers that I can use to order online, or would a different route be more productive?
thanks again
thanks again
https://www.bearing-king.co.uk/how-to...-a-bearing.php
slow up hills
Pop them out and read the type-codes off of them. This explains the codes:
Bikes: Dawes Kalahari, Puch Prima Super Sport, Graham Weigh 853
You could try asking a shop that sells a lot of Campagnolo. Ochsner USA and Branford Bike are well known for small parts as well.
slow up hills
6901 2RS
that's the generic bearing I'm looking for. Branford has it listed on the website but it is "NA"
I'll look at Ochsner
Quoted: 113 Post(s)
Liked 16 Times
1 Super Record bike, 1 Nuovo Record bike, 1 Pista, 1 Road, 1 Cyclocross/Allrounder, 1 MTB, 1 Touring, 1 Fixed gear
Quoted: 303 Post(s)
Liked 136 Times
Might try looking in your yellow pages under bearings for local bearing stores.
Motion Industries is all over the place and with the bearing # you listed you
have all you need. ABEC5 grade would likely gild the lily so to speak as would
ceramic. Motion not likely to have ceramic as a walkin walkout but could
order if you could wait a few days. The cheapest versions are almost
certainly going to be chinese or indian derived so it pays to be particular.
OTOH Motion or similar industrial suppliers don't sell to the bottom feeders
and stock only good quality bearings. LBS is not going to be particular except
for bling seekers so likely to have chinese bearings of unknown metallurgy
with melamine for lube next to ceramics.
slow up hills
I'm looking at some Veloce front hubs I can get dirt cheap ($13) for wheel building; and am interested in the bearing-replacement question.
I purchased the Veloce front hubs also. they just press out and and in. Any bearing shop should be able to get the size in them.
On the rear hubs you can get some mirage hubs on ebay right now for around 15-25 each, they are the same as a veloce hub only not as polished. i purchased a few that way so I could have some spares if needed.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
deleteme
Bikes: deleteme
Quoted: 50 Post(s)
I can't seem to find the Campagnolo part number FH-MI113 anywhere. Is the generic 6901 2RS equivalent?
I like the look of the hub and don't want to chuck them.
Quoted: 1528 Post(s)
Liked 718 Times
Cup and cone bearings are found on high-end gear cause it's a proper high-end way to do it, particularly if replacement cups are available.
Fussing with hub bearings isn't something that ever takes me much time, but I always find it inordinately satisfying... an adjustable bearing is a thing of beauty that doesn't assume you're an idiot, and doesn't expect to be simply replaced at the first sign of trouble.
And it uses less steel.
All you need to do is meaure the bearing OD, the ID and the width. Compare that to the specs on the 6901, which is a real common bearing. You can get that bearing in many versions, that start at a few dollars each and go on up in price, depending on the precision of the bearing and the type of balls and race chosen. A 6901 bearing has a 24mm OD, 12mm ID and 6mm width.
