cateye el450 turns itself off
Old 10-16-08, 07:50 AM
Go Leafs
kgriffioen's Avatar
My cateye el-450 seems to turn off when hitting larger bumps in the road. (happened 3 times this morning) The light is mounted on the handle bars and I have only had it a month or so. Anyone else have this problem with this or any other light? If so any suggestions on how to remedy would be greatly appreciated.
kgriffioen is offline
Old 10-16-08, 08:40 AM
Quoted: 24 Post(s)
Liked 597 Times in 105 Posts
I don't have that light, but suspect that when you hit the bump the batteries are getting knocked from the contacts. Check to see that the batteries make good contact and that none of the little springs or contacts are bent or loose.
hammond9705 is offline
Old 10-17-08, 08:16 AM
Go Leafs
kgriffioen's Avatar
Did as you suggested. No problems on the ride home or on the ride in this morning. Thanks for the help!!
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
