Vintage wheel build Q's(first-timer)
Bikes: Cannondale Bad Boy (King James edition)
I recently aquired an early 70's Gitane tdf...(posted about it couple weeks ago). The project was coming along well until I decided yesterday that it would be easier to disassemble the original Mavic wheels for cleaning.
I ran to the LBS after tearing-down the wheels to buy new spokes and nipples, but spokes were all I came home with. The reason.....the mechanic said the nipples were wheel specific??? Is this true? I have a greater problem now because the original nipples won't thread to the new spokes.
can anyone shed some light o this?
Aaron
Aaron
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
"wheel specific", what's that supposed to mean? If you have deep "V" section rims you might need long nipples, if you have no eyelets in the rims you may need washers...otherwise it's just 2 sizes: 14 ga or 15ga and you probably have a miss-match there. Find a better LBS if they keep talking nonsense.
This is my first wheel build ever....I'm pretty green behind the ears.
Thanks for the help.
Aaron
Liked 1,062 Times
Maybe there's some crucial info I'm not aware of, but it sounds fishy. I'm also surprised they'd sell spokes without any nipples, since most spokes are supplied *with* them from the manufacturer...unless they are a shop that custom-cuts to size and rolls threads themselves (in which case they *really* should know better than they seem to). Good luck with the wheel-building, it's a challenge but it'll pay off eventually. I hope you have good instructions (I use the Jobst Brandt book, myself). My first attempt was a total disaster and the shop had to completely undo and redo my lacing, taught me to "read the instructions"...a lesson I keep relearning again and again
Quoted: 413 Post(s)
Liked 109 Times
I'd go back and ask what happened to the nipples the spokes came with. In my eyes this one of the biggest scams in cycling...selling nipples for extra.
Decrepit Member
Which model Mavic wheels?
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
Quoted: 15 Post(s)
Liked 9 Times
I'm sorry but the LBS guy is as full of **** as a christmas goose.
that rim uses a standard spoke nipple, it doesn't even need spoke washers.
Marty
Marty
Sono pił lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
Decrepit Member
That is a Mavic Montlery Championne du Monde tubular rim, and there is no reason a standard 12mm DT Swiss brass nipple and DT Swiss 2.0/1.8/2.0 double-butted stainless Competition spoke won't work perfectly.
Here's a photo of the eyelets on Montlery rim and a current production Open Pro clincher rim.
Here's a photo of a DT Swiss Competition spoke and brass nipple.
Bikes: 1970 Holdsworth Mistral, Vitus 979, Colnago Primavera, Corratec Hydracarbon, Massi MegaTeam, 1935 Claud Butler Super Velo, Carrera Virtuoso, Viner, 1953 Claud Butler Silver Jubilee, 1954 Holdsworth Typhoon, 1966 Claud Butler Olympic Road, 1982 Claud
Quoted: 10 Post(s)
Liked 11 Times
Nothing special about those nipples, should be no problem getting some to fit.
If you told the LBS you were 'rebuilding some Mavic wheels' then I can see where some confusion may have occured, as some of the modern Mavic 'factory built' wheels probably do need special nipples. I'd go back and explain that the spokes are for 'old-style' wheels using vintage Mavic rims (maybe bring in the rims), and politely ask for the nipples you paid for when you bought the spokes.
What size of spoke did you get, 14g or 15g, etc.?
It's a long story....I'm going with 14G DB on the front and regular 15G on the back. I'm rethinking things now, so it's hard to say what exactly I'll do regarding the spokes.
Thanks for the help guys.
Aaron
Aaron
