Jannd Expedition rearrack and Ortliebs backrollar panniers.
Still learning.
Bikes: Surly LHT
Does anybody run this setup and where did you place clips on top rail? Both in close together or spread out? The bottom clip, did you use the top option or the bottom to connect to rack rail? Been playing around with different positions and haven't found one I'm super happy with yet.The Ortliebs are backroller classic.
https://www.jandd.com/detail.asp?PRODUCT_ID=FREXP
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Have no clue...I just bought the Ortliebs, the Jannd racks (front and rear) are still in the shipping box at the house, the bike is in pieces and I am 500 miles away
Let me know what works
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
bragi
Bikes: LHT
Oddly enough, I use a Jandd rack and Ortlieb panniers on my touring (only) bike, and I have the clips on the top rail almost as far apart as I can get them, and the lower clip as low as the rack will allow. My opinion is that you're basically making a triangle with the contact points on the rack, and you want to allow as little play as possible, which is most likely to happen if those contact points are at the, well, points of the triangle. Also, I've found that using #10 inserts on the clips at the top rail allow for a lot less rattling. I had #11s on for a long while, and that turned out to be a fairly bad choice.
Still learning.
Bikes: Surly LHT
Still learning.
Bikes: Surly LHT
Called REi about the size #10mm inserts and they didn't show any on there computer just the#11 and #8's and they checked Ortliebs page. I just went ahead and used tape to build up diameter. The #8mm were to small and #11mm were too big, but tape made it just rite.
bragi
Bikes: LHT
https://www.wallbike.com/ortlieb/accessories.html
BTW, the Ortlieb USA people seem a little questionable....
