7-speed STX-RC freehub body cone
Greetings - I just got a 7-speed STX-RC freehub body to fix my hub. The old cone will fit but with the new freebody a large gap now exists around the cone exposing the bearings. Thus I am looking to obtain for the proper shimano part numbers for the right rear cone and dust cover/caps to complete the repair and/or where I might be able to order them. Thanks for your help.
Liked 6 Times
Am I right in guessing that your old cone has the dual split-ring type of seals? Because if it does, you might be able to simply remove them and put the larger rubber lip-type seal in the groove instead. I've never tried that myself that I can recall, but it would only take a minute to see if it was going to work out or not.
