What front rim for this clyde?
Bikes: Mostly schwinn... few classics
So I am done with the current one.. it just keeps failing on me. I am in need of a strong front road rim. The bike is a 2002 schwinn super sport. 700c tires and is my daily commuter. I am currently 270 lbs and do from 80 - 130 miles a week on various conditions. I was looking into touring rims as they seem like the best bet (and it's what I have on the rear) but I am always up for suggestions.
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
I like the Mavic CXP33 rim on the front. Not too heavy but strong. But since you have a touring rim in the rear, I'd have second thoughts. I may be wierd but a 23 mm rim in the front and a 21 in the rear would throw my mind off balance!
So depending on the height of your front rim....
velocity deep vee or or fusion rims are both very nice and strong with lots of colors.
https://www.velocityusa.com/default.asp?contentID=586
The green would be sweet.. but from what I found it's out of my price range right now!
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
Quoted: 9 Post(s)
Liked 22 Times
Look at the Weinmann DP18.
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
Mad bike riding scientist
Quoted: 6214 Post(s)
Liked 4,212 Times
I wouldn't buy anything until you've had a chance to check out Veloswap this Saturday, however
Stuart Black
Stuart Black
If your new back wheel is working well then I would use the same type and builder. Back wheels are under much more stress then front.
Bikes: Old Bike: 1975 Raleigh Delta, New Bike: 2004 Norco Bushpilot
Liked 5 Times
What rim do you have on the rear? Go with what works for you, if your replacing a rim on a wheel that's breaking spokes, then at a minimum your replacing the rim and all spokes, decent front hubs are reasonably priced, so if the hole count is different, just add a new hub and get a new front wheel built, by the same guy that built the rear. If the old hub can be reused, then just use it......
Liked 4,212 Times
Only the largest bicycle swap meet on the planet
Stuart Black
Stuart Black
Quoted: 12190 Post(s)
Liked 1,495 Times
What size tire are you using?
