newb question: Bent spokes are still good?
Old 11-06-08, 03:13 PM
everyday I'm hustlin'
brandonspeck's Avatar
Bikes: Surly Crosscheck, Surly Steamrolla
Hey guys,
I was riding home from classes yesterday and a longboarder hit me, and his skateboard bent a few of my spokes putting my wheel horrible out of true.
The wheel was hitting the brake pad, and I fiddled around with a spoke wrench and got it so the rim no longer hits the brake.
But a couple of the spokes are slightly bent... they're still good right?
brandonspeck is offline
Old 11-06-08, 03:24 PM
50000 Guatts of power
127.0.0.1's Avatar
the life of the spokes has been reduced by quite a bit
they may last they may not. be sure, and get them replaced. also the spoke nipple
127.0.0.1 is offline
Old 11-06-08, 03:35 PM
Rat Bastard
mcoomer's Avatar
Bikes: Cannondale Prophet, Specialized S-Works SL2, Specialized S-Works Stumpjumper
Replace the spokes and nipples that were tweaked, true the wheel up, and then check the tension on the spokes. If you're wheel was badly damaged you may have to really tighten those spokes to true the wheel, in which case you may need a new rim.
Mike
mcoomer is offline
Old 11-07-08, 05:23 PM
smurfy's Avatar
Bikes: Classic lugged-steel road, touring, shopping, semi-recumbent, gravel
Quoted: 46 Post(s)
Liked 81 Times in 32 Posts
Bent spokes shouldn't be a problem if they can be straightened and they're not "kinked".
smurfy is offline
Old 11-07-08, 05:35 PM
Bikes: like 15. my favorite a 1951 schwinn spitfire cruiser. also have a 1959 amf roadmaster, 1962 jch deluxe cruiser among others.
replace. spokes and nips are cheap, you will know that they are right, and learn about wheel maintence and practices as well. even though bent spokes may work, they are never quite the same. but in the endm its up to you.
ogbigbird is offline
Old 11-07-08, 07:38 PM
o.O
Seggybop's Avatar
It's totally fine to use spokes that have been bent, as long as it wasn't a severe bend. In some situations it's actually required to bend spokes a bit to lace them.
The real issue is not that the spokes themselves are bent, but that they're bent while laced to the wheel in what should otherwise be a proper configuration. Normally, if you lace a wheel with bent spokes, the tension they're under forces them to straighten out. If you have a built wheel with visibly bent spokes, this means that either the overall spoke tension in the wheel is significantly below what it should be, or the rim has been deformed so the bent/loose spokes are attached to a bent/flatspotted area of the rim.
Unless the spokes have been scraped/gouged, they will be fine. It's a lot more likely that it's the rim that's messed up.
Seggybop is offline
Old 11-07-08, 09:05 PM
z415's Avatar
Bikes: Trek 1000, two mtbs and working on a fixie for commuting.
It should be fine if it is just for commuting.
z415 is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
