Rear derailleur not shifting to big gears
After a pretty bad crash, I got most of the bike fixed. Trued the wheels, straighten the handlebars and brake levers, new grip tape. I had to adjust the rear derailleur but it won't shift to the two largest cogs. Do I need a whole new derailleur? Or is the arm just bent?
Bikes: like 15. my favorite a 1951 schwinn spitfire cruiser. also have a 1959 amf roadmaster, 1962 jch deluxe cruiser among others.
after you check to see if the derailleur is bent, try checking your cable slack and your limitation screws. although it is unlikly that a crash could have changed this setting, stranger things have happened. if the derailleur is bent, go buy a new one unless you think you can just bend it back and you are ok with that. if your derailleur hanger is bent, you may need to take it to a shop to rebenf it if you are not comfortable doing it yourself.
adjustment, then if not, replacement. without pictures, my help can only be general.
Great State of Varmint
Liked 15 Times
From behind with the camera looking down to show where the two pulleys are. First shift it as far as it will move so that it trying to get to where it won't go. We need to look at the angle of the derailleur wheels and body and where it attaches to the bike-frame.
Rather like this with the RD oriented on the gears you can't shift to:
