Fixie or dumpster
Fixie or dumpster
Old 03-25-04 | 10:46 PM
halfspeed's Avatar
20 Anniversary
Bikes: are better than yours.
Fixie or dumpster
I picked up an 80's Bianchi mid to low end frame at a bicycle junk yard and I'm trying to decide if it's worth saving. It has deraillers, a head set, cranks and pedals but I'd do a fixie or singlespeed conversion. It seems OK, but it looks like it had a nasty chain suck and I'm wondering if the damage is enough to make it unsafe. I've cleaned off the rust with some naval jelly and a wire brush and attached some pictures. What do you think?
halfspeed is offline
Reply
Old 03-25-04 | 10:48 PM
halfspeed's Avatar
20 Anniversary
Oh, and one more thing. It really is that awful lavendar mist color. The pink globs are just naval jelly residue.
Reply
Old 03-26-04 | 11:02 AM
Retro Grouch's Avatar
Titanium Club Membership
20 Anniversary
You didn't show the most important part. If the frame has horizontal dropouts, I'd repaint it and build it into a fixie for sure. If the dropouts are vertical, I'd be a lot less enthuiastic about it.
Retro Grouch is offline
Reply
Old 03-26-04 | 03:01 PM
Rev.Chuck's Avatar
The Red Lantern
Sheldon Brown Memorial - Donating
20 Anniversary
SOunds like a good fixed project to me
Are you a registered member? Why not? click here to register. Its free, and only takes 27 seconds!
Help out the forums, abide by our community guidelines.
I am in the woods and I have gone crazy.
Rev.Chuck is offline
Reply
Old 03-26-04 | 04:47 PM
John E's Avatar
feros ferio
25 Anniversary
If you have room, time, and budget for it, it is probably worth fooling around or experimenting with. Even if the chainstay eventually cracks (been there ... done that with a Peugeot UO-8), the failure should be medically benign to the rider.
John E is offline
Reply
Old 03-26-04 | 06:32 PM
GT_ATB32's Avatar
Sport Class Racer
20 Anniversary
Bikes: 2003 Leader Bike LD 515 <----race bike, 1991 Cannondale SR 400, Haro Escape 8.3(dead, will revive to ride urban on),2003 Ironhorse Hollowpoint Expert, Random Frames and BMX stuff
i rode my gt mtn bike hardcore with worse chain suck, but u might have to worry about that chainstay being rusted on the inside
GT_ATB32 is offline
Reply
Old 03-26-04 | 06:45 PM
BlastRadius's Avatar
Direct Hit Not Required
20 Anniversary
Bikes: Leopard DC1, Ridley X-Fire, GT Zaskar 9r
Good luck getting that fixed cup off
BlastRadius is offline
Reply
Old 03-27-04 | 09:18 AM
legalize bikes
20 Anniversary
Bikes: too damn many
stick the flat edges of the cup in a bench vise, and use the frame to twist it off. this method will remove the meanest of fixed cups in a matter of seconds, instead of hours with the box-end wrench and hammer, or whatever method you try.
legalize_it is offline
Reply
Old 03-27-04 | 09:33 AM
20 Anniversary
My LBS tried that. If I recall the flats of the cup were very thin so there wasn't very much metal to grab onto. Then they used some professional looking tool and with two people and a huge leverage bar couldn't get it loose. I ended up using Sheldon Brown's method (https://www.sheldonbrown.com/tooltips/bbcups.html) at home to get it off. I had to put the bike on the trainer, sit on the saddle, and use leg power to break it loose.
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
