How to repair wobble on the rear wheel?
Old 11-07-08, 11:26 AM
I've got an old Raleigh road bike. Recently I have noticed, that there is an odd sound comming from the rear of the bike when I input more power. The sound resembles a sound, which is made by not fully shifted gear, though the gear is in the right position. Oiling everything did not help.
I have noticed, that the rear wheel wobbles a little to the sides (a small diagram in , where red represents forks, bold black is a tyre and blue shows how the wheel wobbles).
has anybody suggestions what to do? I have never experienced problem like that. Thank you.
mantasdienys is offline
Old 11-07-08, 11:31 AM
Prefers Cicero
cooker's Avatar
Bikes: 1984 Trek 520; 2007 Bike Friday NWT; misc others
Quoted: 3943 Post(s)
Liked 117 Times in 92 Posts
If the wheel can wobble from side to side when it is not spinning, then the axle cones need to be tightened slightly. If you mean that when you spin it, you can see the rim move closer to a brake pad at one point in the cycle and then away again, it means a section of the rim is "out of true" and a bike shop can make tiny adjustments to the spoke tension to straighten it.
cooker is offline
Old 11-07-08, 11:33 AM
Prefers Cicero
cooker's Avatar
If the bike tries to shift gears when you pedal hard, try oiling the deraileur cable where it passes under the bottom bracket (between the pedals).
Try sheldonbrown.com for more tips.
cooker is offline
Old 11-07-08, 04:12 PM
Life is good
RonH's Avatar
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times in 10 Posts
Is the wheel properly seated in the dropouts?
RonH is offline
Old 11-08-08, 02:39 AM
Yes, it is. Probably, the problem is with the axle. I will have to tighten up the cones, as described in #2. The wheel is quite true (I did trueing not so long ago)
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
