Tire blew off of rim while in garage
While sitting in my living room I hear what sound like a gunshot coming from the garage. Uppon investigation I see the front tire blown off the front rim of my 2007 Cannondale touring bike. Rims are DT Swiss TK 7.1 with Schwalbe Marathon 700 x 35 tires. I keep them at 85 PS
There is no vilable damage to the rim and the tires have just over 1300 miles (tread still looks like new). Appearently the bead becam unseated.
Is there anything other than defective tires that would cause this to happen?
AL W
AL W
Tire was still mounted from when the bike was bought at the LBS. Never had a flat till now. When mounting the tire with a new tube it went back on the rim with very little effort, a lot easier than any other tire I have ever mounted.
Quoted: 137 Post(s)
Liked 81 Times
I had the same happen with Schwalbe folding Marathon Supreme, 700x35 on Synergy Rim, very loose fit, the tire had been fine on another rim for 1/2yr but blew spontaneously after three days on the Synergy. The tube was shreaded along the rim side,,ie. in the middle of the rim. Consensus here was pinched tube but I'm not sure, I wonder if there was a bit of aluminum flashing poking through a marginal rim strip made of cheap duct tape. I've remounted with a new rim strip,tube and anxiously wait to see if it happens again, pumped to 80psi.
Location: Rural Missouri - mostly central and southeastern
Bikes: 2003 LeMond -various other junk bikes
Quoted: 78 Post(s)
Liked 44 Times
Whether or not this event remains a mystery is anyone's guess.
Bikes: 1997 Specialized M2Pro
A pinched tube might take a while before it shows up as a problem. My dad recently crashed because of a front tube blowout while going down a hill. He had replaced the tube a few months ago and mistakenly put a 28-32mm tube in a 25mm tire. The extra rubber caused him to get the tube partially pinched near the valve stem and it blewout at a bad time.
My one and only flat on my commuting bike happened 7000 miles after installing the tires/tubes (tires lasted another 3000 miles before I finally replaced them and never once flatted because of a puncture). I had twisted the tube slightly during the install and over time, the rubber wore thin from rubbing against itself and eventually caused a hole.
aka Phil Jungels
Check the edge of the tire lip, VERY CLOSELY.
I had a tire one time that kept blowing tubes for no apparent reason, and finally determined that the edge of the tire, right at the bead, was "bent" or "creased" or "nicked" and was the reason.
That imperfection allowed the tire to work it's way off the edge of the rim at that exact spot, and it always blew the side of the tube out. The dealer even changed the tube a couple times, thinking I was doing something wrong.
My LBS gave me a new tire and it never happened again. He even gave me a half dozen tubes to replace all the tubes I bought from him.
The vast majority, like 99.9% of the causes of these spontaneous blow-outs are due to pinched tubes during tyre-mounting. Telltale signs of pinched-tube blowouts are HUGE rips in the tube. Typically star-shaped and towards the rim-side of the tube. Unless you've done the following, you cannot rule out an improperly installed tyre:
1. give tube 1-pump to form it into round shape instead of flat
2. if 1/2 tyre already mounted, push valve into rim and stuff tube into tyre
3. start pushing remainder of tyre over starting near valve-stem and go over valve-stem along the way (DO NOT save valve-stem area for last)
4. after tyre's installed, push the valve-stem into the tyre to ensure that tube in that area isn't pinched
5. after tyre's fully mounted, let out some air from tube so you can pull tyre sideways and look down into gap between tyre and rim-edge
6. look for pinched tube showing, then move over a couple inches and pull tyre sideways again and look
7. work your way around entire circumference of tyre, then inspect the other side all the way around
8. only after ensuring no tube is showing anywhere around entire tyre would you then pump up the tube.
Bill
Bikes: Specialized Globe Sport, Specialized Stumpjumper FSR Pro
Thanks Dannon for a good 'how to'. If I could only figure out what a 'tyre' is.
Great State of Varmint
Liked 15 Times
Number 1. up above is very important. Put just enough air in the tube to be able to feel it with your fingers as a tube. And gently work it up into the tire before you fully seat the second half of the clincher's edge up and over the rim.
I've had a cheap tube blow-up before in my garage one night. I was expecting the police! It went off like a 9mm. BANG!! LOL.
Older "newbie"
Bikes: Fuji Newest 4.0 just bought 7/26/08!
That happened to me but in my living room! I nearly S&*T myself it was so loud. Turned out that the kid at the LBS I bought it from 2 days earlier told me to keep the tires at 120lbs. Looking the the tire side it said 90lbs. I keep them at 90. Man it did indeed sound like a gunshot!
Was the tyre damaged when it blew? Typically the sidewall numbers are 1/2 of the actual pressure required to expand the tyre bead enough to blow it off the rim.
I'm glad you're having some luck with them, but I still think they are crappy tires. And, it sounded like this guy had the same problem.
Incidentally, please note, although my experience is the opposite of yours, I do not assume you are full of crap, er, rubbish.
Bikes: Dawes Kalahari, Puch Prima Super Sport, Graham Weigh 853
If you'd posted like that in the first place, I would not have disagreed. Also, I only wanted to say that I disagreed with your blanket statement that Schwalbe tyres are crappy, not that you were crappy, or trashy, or rubbish
Problem Solved
After four blowouts, and LBS telling me I put tube and tire on wrong or had snake bite. I tried brand new tires and tubes. One blew just 800 feet into ride, and another after one mile. Been riding bikes and mounting tires for 50 years so do have some experience. That makes 4 blowouts in 4 months.
Built a brand new front wheel, and no more blowouts! Am looking for cracks or other imperfections now on old rim. If LBS did not dismiss me out of hand thay might have been able to sell me a new wheel.
BTW riding with same tires that blew off, for quite a few miles now.
Quoted: 3370 Post(s)
Liked 5,491 Times
They were very *tight* when I mounted them. I have had no problems whatsoever with them.
How long ago were those Synergy purchased? I'm wondering if Schwalbe changed the bead dimensions.
Quoted: 137 Post(s)
Liked 81 Times
the synergy was purchased last fall. The Supreme is much looser than I'd prefer and about a year old. It's a folder. I've been running a Supreme on the rear and Pasela TG on the front,,ridden through glass a few times with no flats.
