Handlebar help
Handlebar help
Old 11-10-08, 09:39 AM
gurry's Avatar
Bikes: 1987 bianchi campione d'italia, 1970's eatons glider, 1990's hybrid, 1992 trek antelope
Handlebar help
Say I need some advice on how to remove these handlebars. On the arm rests it says profile. I'd like to put on drop bars.[IMG][/IMG] [IMG][/IMG]
gurry is offline
Old 11-10-08, 09:54 AM
Quoted: 2026 Post(s)
Liked 1,095 Times in 741 Posts
Look under the foam bar padding at the very front of the bars. The U-shaped end connector piece probably removes giving you open ends on both sides.
BTW, substituting drop bars is going to be far more complex (and expensive) than just replacing the handlebars. Do a search as this topic has been beaten to death here more than once.
HillRider is offline
Old 11-10-08, 10:23 AM
gurry's Avatar
Thanks for the post, I was thinking of swapping them out when I can find a suitable donor bike. The trouble is I'll probably fall in love with the donor bike and keep it.
gurry is offline
Old 11-10-08, 10:28 AM
TallRider's Avatar
Quoted: 128 Post(s)
Liked 12 Times in 10 Posts
I had those bars when I built up my first road bike back in 1995. HillRider is right about the location of the U-shaped connector. If I remember, that front piece wasn't very long, it probably doesn't extend very far under the foam padding.
Not sure I agree with HillRider about the expense in this case. Presumably your stem has a 26.0mm clamp (possibly 25.4) and you can get road bars with either clamp diameter pretty cheaply.
Since this bike has down-tube shifters, the only other things you'd need to get are brake levers and new handlebar tape. Oh, and new brake cables since the mountain bike brake levers currently mounted on those bars have a different cable-end. You'll be fine with the current cable housing as they look slightly longer than is necessary for a road bar.
"c" is not a unit that measures tire width
TallRider is offline
Old 11-10-08, 10:45 AM
gurry's Avatar
Thanks for posting. I did not know mtb brake cables have different cable ends. Always good to know in advance.
gurry is offline
Old 11-10-08, 11:53 AM
Good point. I didn't notice to the downtube shift levers as I saw the MTB-type brake levers and assumed (incorrectly) they were also the shifter location. The fact the bike has caliper brakes is also a plus.
New brifters are always a big expense in these conversions and are often the deal breaker.
Old 11-10-08, 01:58 PM
gurry's Avatar
Thanks guys. Here are some more pics.
gurry is offline
Old 11-10-08, 03:19 PM
TallRider's Avatar
Quoted: 128 Post(s)
I think it's a pretty bike, a nice (probably pretty basic) steel frame and functional parts (looks like SunTour). Don't break the bank, but you can get a handlebar, brake levers, new bar tape and brake cables for probably $70 new and less if you go used or eBay or have a local bike co-op.
Totally reminds me of my first build of my Raleigh from 1995 to 1997, because I had those bars (in day-glo yellow) with mtb brake levers and down-tube shifters.
Also, it looks like an older leather saddle- you might want to use some leather conditioner on it, and maybe add some tension by tightening the bolt if the saddle sags too much in the center (but be way careful with this, and you can read lots of other threads on tension in leather saddles).
Old 11-10-08, 04:11 PM
DannoXYZ's Avatar
Quoted: 109 Post(s)
Liked 9 Times in 6 Posts
I believe those are 1-piece handlebars. You have to remove the grips & brakes from one side completely. Then remove the stem from the fork and slide it out the free side. May need to rotate stem to get around some of the curves.
DannoXYZ is offline
Old 11-10-08, 04:41 PM
Real Men Ride Ordinaries
fuzz2050's Avatar
Quoted: 17 Post(s)
Liked 3 Times in 3 Posts
Those are pretty cool looking bars, maybe you should rethink getting rid of them. It's always fun to have a unique bike.
fuzz2050 is offline
Old 11-10-08, 08:49 PM
Right, they are but, as currently pictured, they make a complete loop with no place to have the stem exit. Removing the U-connector gives the stem a place to escape.
Then, of course, the OP will have to completely remove the bar padding, arm rest and brake lever from one side to remove them.
Of course, he could just hacksaw the stem clamp to free them.
Old 11-10-08, 08:56 PM
Great State of Varmint
Panthers007's Avatar
Liked 15 Times in 15 Posts
I second the possibility of a hacksaw. Those aren't handlebars - that's a maze.
Panthers007 is offline
Old 11-10-08, 09:07 PM
DannoXYZ's Avatar
Quoted: 109 Post(s)
There's a U-shape piece at the top. It's interchangeable with another piece that holds bar-end shifters. Remove the forward grips and you should see how it attaches.
DannoXYZ is offline
Old 11-11-08, 02:31 AM
Joshua A.C. New's Avatar
Bikes: Iron Monkey: a junkyard steel 26" slick-tired city bike. Grey Fox: A Trek 7x00 frame, painted, with everything built, from spokes up. Jet Jaguar: A 92 Cannondale R900 frame, powder coated matte black with red and aluminum highlights.
Nah, man, those are 80s aero bars. I'd keep 'em.
Joshua A.C. New is offline
Old 11-11-08, 01:53 PM
gurry's Avatar
Thanks for the input. Here is a pic of the same bars set up different than mine. Maybe I should ...[IMG][/IMG]
gurry is offline
Old 11-11-08, 02:40 PM
Why do you want to take them off? I think theyre cool!
firereign is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
