designing a safer cycle/tricycle
I've been thinking for some time of building a bicycle or tricycle where the rider would be surrounded by a roll cage. This cage would be triangulated for strength, stiffness, and light weight, and would double as the frame-wheels, pedals, the seat, etc., would bolt right to it. For weather protection and/or aerodynamics it would be easy to add a cover. Is anyone else thinking this way, and if so, can I pick your brains for some good ideas for the design? Thank you, Charles Brown 1875 Sunset Point #206, Clearwater, FL 33765
Bikes: Peugeot Hybrid, Minelli Hybrid
It wouldnt do much for safety, since it wouldnt stop the rider from striking a hard object when they fall or are hit. However a device to hold an umbrella over the rider might attract some users
Bikes: Trice Q; Volae Century; TT 3.4
A velomobile with an exoskeleton might be interesting if you were able to keep the weight down.
pedalphile
Bikes: trek 1200, 520, Giant ATX 970, Raleigh Talon
Quoted: 5 Post(s)
Seems like weight is the major concern.
I think the idea has merit.....in florida or some other flat as a board place, but, even moderate hills would kill you.
I think a better idea might be some sort of airbag system that would deploy behind you. It might even be carried in a backpack. Such a system might help you against being hit from behind, which, imo is the one type of accident we have little control over. Side or frontal impacts, I think are best avoided by staying awake and riding defensively.
Quoted: 5 Post(s)
Liked 11 Times
Sounds like you'd end up with a device no one would want to ride. One of the great joys of bicycles is the minimalism.
There's a big difference between 20 lbs & 30 lbs.
There is a guy around here with a motor scooter with a roll cage. It looks like it gives the illusion of safety without signifcantly increasing safety. More weight far away from the center of balance will make evasive manuvers harder. Trikes are already suffering from weight problems.
Interesting thought, but historically a blind alley.
Quoted: 77 Post(s)
Liked 19 Times
Many inventors have had similar ideas; there is no market for something like that.
If you want to build one for yourself, then fine.
You'd be injured and dying before the suit fully inflated.
. . . but the idea seems interesting. Whether or not it could be practically developed for bicycle use remains to be seen, and I'm still not certain I'd want to wear such a suit.
My thinking is with others, here, that to build a cage around a bike tends to defeat the purpose of cycling. You really couldn't go anywhere. Might just as well use a trainer indoors, surrounded by the walls of your home.
. . . but I don't mean to knock your idea. Worse vision has resulted in useful inventions.
Caruso
You mean like this?
This is only a Polaroid, let me show you a better picture:
Well, it definitely can be built. This one used Kevlar though, which is a bit pricey. The pictures show the Type 6 in 1989 and 1990. There are aluminum tubes in the canopy, but they are molded into the Kevlar, not welded to the bike frame.
I started by attaching two six-foot long aluminum tube to the top-tube, using ten stainless steel hose clamps. The hose clamps are the kind used for automotive radiator hoses, two inch diameter.
I plan to build a new velomobile, but next time I will make the seat lower, and further back Lowrider style, and I will make the fairing wider. This fairing was only twenty inches wide. Next one will be at least twenty four, maybe twenty six inches wide. And wider at the rear too, the bike in the picture has a rear fairing only fourteen inches wide. The front and rear fairings should be the same width.
It worked for me, good luck!
surly old man
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 46 Post(s)
Liked 42 Times
I want cupholders
Cross Check Nexus7, IRO Mark V, Trek 620 Nexus7, Karate Monkey half fat, IRO Model 19 fixed, Amp Research B3, Surly 1x1 half fat fixed, and more...
SB forever
SB forever
Good luck. People make shelled bicycles for high speed but they don't have frames (not ones that would be at all safe) and they're made to specifications that would be impossible to deal with in the real world.
The immediate trouble I see is dealing with bad terrain, especially slick areas. It'd have to be a tricycle because the shell will immobilize you too much to deal with balance on bad terrain.
I imagine it still won't be terribly safe or it'll be too heavy (even if you use all carbon fiber). Maybe it could be an electric assist machine though? You could even try some kind of high end thing where you have solar panels, pedal, and have a rechargeable battery. The pedaling and solar panel would just provide extra distance.
Most users wouldn't pedal though. Your pedaling would be similar to the solar panels on a gloomy day. But the use of bicycle parts might mean a low cost efficient machine.
Edit: Low cost if PV cells ever get down to a reasonable price ( < $.05 per kilowatt hour ).
pedalphile
Quoted: 5 Post(s)
You mean like this?
I had no trouble handling the velomobile in a cross-wind.
Maybe 'cause the top is rounded, where the sides meet the roof.
I even had it out on a day with 60MPH wind gusts.
I have a pilots license, so I have to say it's no different than landing a plane in a crosswind.
Quoted: 117 Post(s)
Liked 71 Times
I'll echo the sidewind concern--customers of mine who race time trials and tris mention wind pressure with deep aero rims, let alone a fairing over the bike! Enough weight to stabilize this machine in the wind will be too much for most cyclists. Even at 2000 pounds, a VW Golf on a windy bridge is plenty scary! How about just designing a bike for full coverage fenders?
Those of us who ride in wet weather know that more water gets you from below than from above.
Reminds me of this. Op must have already found this https://en.wikipedia.org/wiki/BMW_C1
Note it was produced only from 00 to 03.
Problems with seatbelts and helmets causing stress are mentioned.
Calculating the forces a helmet might have on a neck should be easy enough if someone cares enough.
I think the style problem is far worse than the weight issue.
Balance with that thing will be interesting.
I see how that provides some added safety when falling sidewards.
Frontal impact not so much.
I would adapt the basic design of the bmw c1 here.
Would just guess adding top tubes is the same amount of weight as the frame.
Make shape just like something which could be aerodynamic.
Build and try
Build and try
Bikes: Bianchi San Remo - set up as a utility bike, Peter Mooney Road bike, Peter Mooney commute bike,Dahon Folder,Schwinn Paramount Tandem
Here's a link to a photo of a good old Airstream trailer.
https://www.flickr.com/photos/jackjon...7602790081263/
Notice how the top and ends are rounded? Maybe that's why Airstream trailers are the only ones left after a hurricane or tornado rips through a trailer park.
And here's more about the BMW C1:
https://www.carenthusiast.co.uk/shows/bmw_3.htm
