Just started training with Power? Post your questions/comments here!
#226
RustyTainte
Bikes: zilch
I have a real, long, nasty, hilly race coming up soon. The PT has added significant weight to the bike. Should I switch wheels without the PT just to give me that little extra weight reduction? OR will the PT benefits outweigh the added weight?
#228
Writin' stuff
Liked 19 Times
Especially if it's not an A race, use the powertap. The data from races is very useful.
If it's an A race, your only goal is to win. If the powertap won't help you win that specific race, then don't use it.
#229
RustyTainte
Bikes: zilch
That's the thing. I did well last year as a 4. I didn't use the PT. This race could really add some points to my upgrade if I do well - and I think I can.
#230
RustyTainte
Bikes: zilch
Wheels + PT seems to be 3 pounds more or so.
I may be over thinking it. But I haven't done this race as a 3 and I heard it's attack after attack on the massive climb back to the finish line.
#235
Batüwü Creakcreak
Quoted: 228 Post(s)
Liked 288 Times
3 lbs is pretty significant, I figured it might be a pound at the most.
I'd still like the data aspect of things, but if it is a hilly race then the weight will matter.
#236
RustyTainte
Bikes: zilch
Yeah, see I had carbon wheels and the lot. This thing is wired and laced to heavier wheels. It really jumped in weight. I'd like to put the PT on another set of wheels but my wife's job is up in the air and it wouldn't be a wise decision right now.
#238
Power data really matters for training not so much for racing IMHO. I dont see myself using the PT for many races this year (if any). Ill run the PT head in computer mode.
#239
Batüwü Creakcreak
Quoted: 228 Post(s)
Liked 288 Times
I think having power data from a race helps look at training. You can go back and reverse analyze what you were doing right/wrong, whether you attacked at the right time, how close you were to your limit, where you pulled when you shouldn't have, etc etc etc.
The biggest plus is that you can train using your power data to work on your weaknesses if there's a particular pattern that emerges from your races. So you can 'race simulate' so you fare better the next time.
I wouldn't even look at the meter during a race, I plan on taping mine up before races or just not looking at all (hard for me).
#240
Making a kilometer blurry
Yeah, I've gotten a lot of useful info from race data. Especially since my race strategy involves a 100% maximal effort of 1 minute, I can compare my ability at the end of a race to my ability when fresh and testing.
#241
Bikes: 2000 Cannondale CAAD3 Triple 105/Ultegra
Stomp tests--is there an optimum gear combination?
#242
To get more precision in the torque value, I go small ring, big cog. I also slowly roll the bike back and forth so the crankarm passes through being truly level. I average a few max value readings with random wheel rotation spins between them.
#243
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
what is a typical "good" IF for a 3 hour road race?
#244
RustyTainte
Bikes: zilch
I upload my PT data to TrainingPeaks software. However, it's at work. How can I upload this info onto my home computer this weekend in order to transfer it to my work computer on Monday?
#245
Bikes: 08 Trek Madone 4.5
You don't have to. Your PT head will save them as different days and rides. I don't really remember up to how many hours though. It's a fairly good bit though.
#247
Rawwrrrrrrrrr!
Bikes: 2009 Specialized Ruby Sworks SL w/SRAM Red; 2006 Fuji Team RC; 2008 Felt F1x; 1980's Lotus Excelle; Mangusta FG/SS; Rossin (yet to be built up)
no, if you clear the PT head, you clear all the ride data. trust me i know - thought i had one saved on the computer, cleared the data and then found out i hadn't saved the file before closing WKO.
#248
RustyTainte
Bikes: zilch
Tanx
Or .... Can one upload into PowerAgent, export as a csv file, then import into WKO+?
I could try that. Just not sure about data integrity.
#249
Yeah, when I borrowed a PT for a week I imported into PowerAgent and then exported to WKO. Although I did do several rides a day and reset in between and had no problems importing it later.
#250
RustyTainte
Bikes: zilch
Maybe if you hold both buttons down for a given time it clears everything. I dunno. Kind of afraid to try it.
