Just started training with Power? Post your questions/comments here!
#1651
Bikes: 2006 Cannondale CAAD8
It is my understanding that Quadrant III is for active recovery and not Quadrant IV because the higher pedal velocities at the same pedal force would put your power levels over active recovery levels. Quadrant IV is associated with higher power levels (as in around FTP or a little lower) that happen to be at high velocity too. In the example posted the persons FTP is 300 watts and you can see the line corresponding to all the velocities and forces. Active recovery should be under 55% or so of FTP. That means for an FTP of 300 watts active recovery is less than 165 watts. The border of Quadrant III and Quadrant IV is around 1.42 m/s and under 211N. So middle of the pedal force is 105 N. 105 N and 1.42 m/s is ~149 watts. So as you can see I am sure it is possible to do active recovery in the beginning of Quadrant IV but I think it is just a guidline to be at the very least close to Quadrant III. Along middle of Quadrant IV is over 2 m/s (~110 rpms). I am not sure that much active recovery should be done at those rpm's as even if the power levels are low the fatigue from high velocity is still there.
#1652
Then why did you say above that no active recovery should be done there?
#1653
My point is that at the beginning of quadrant 4 you become very close to going over 55% of FTP which seems to be the accepted place for active recovery to end. Also I am not saying that active recovery is ONLY quadrant 3 and as soon as you just cross into quadrant 4 you are no longer doing active recovery. The example I gave actually showed that the beginning of quadrant 4 is still active recovery.
#1654
I don't know how you define the beginning of quadrant 4, but I do know that any power from 0 to FTP can be accommodated at any cadence above that which divides quadrants 3 and 4 or pedal force below the quadrant 2/3 boundary value. Sketch in the 165 W and 100 W isopower line and it should be clear.
#1655
I am guessing your question is why is 100 watts (say 50 N and 2 m/s) which is clearly towards the middle of quadrant 4 not active recovery? My educated guess would be 2 m/s (~110 rpm) can not be active recovery due to the large amount of velocity leading to premature fatigue due to the fact it is way past the dividing line for the quadrants. I would assume that anything to the right of the 1.42 m/s pedal velocity line would lead to premature fatigue from excessive velocity and anything above the 211 N line would lead to premature fatigue due to excessive pedal force (for this specific example). This is my understanding of the benefits of quadrant analysis. To see the balance of your personal force and velocity ratios. Also this graph is solely based on the individual. Mine will look different from yours which will look different than this example. If I understand right that would make this descriptive.
If you still feel quadrant 4 could be active recovery would you agree that 100 m/s and 1 N is active recovery? It is still 100 watts which falls into active recovery.
Rereading the thread I see that I did oversimplify the boundaries way to much originally. Hopefully this post clarified. If I misunderstood what you were saying please let me know.
#1656
Bikes: yes please
the answer may be in here somewhere--but I'm too lazy to read 67 pages of PT questions/answers. sorry.
Tech question:
My head unit is not reading the PT hub (no sensor indicator, no readings). While I was on the rollers the other day it was giving me some strange watts, I stopped and zero'ed the torque and then it couldn't find the hub anymore. Just like that...
I changed the bats two weeks ago (head unit and hub) the connectors are fine and in good contact, it still reads cadence fine. I didn't see any problem with the wire or sensor on the seat stays.
Am I missing something? Any suggestions?
Tech question:
#1657
grilled cheesus
What are the basic/default power zones in WK0 based on or off? From reading it seems everyone is pretty much using Coggan Zones, which WK0 can calculate. Later.
#1659
grilled cheesus
^^^^ really? i must be missing the other options. the default are there, six of them, then under options Coggan is there to be calculated. i was just curious what or whos the default zones were. later.
grilled cheesus
^^^^ ah ha. in 3.0 on Coggan Power Levels are showing up. i opened up 2.2 and it appears as you have shown above. interesting. thanks for the clarification. which are you using? later.
i am using 2.2 i dont plan to upgrade to 3.0 for atleast a couple of months if at all. ill see what others say about the usefulness of it.
#1663
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
I loaded the trial of 3.0 and played with it for an hour or so. Not impressed.
#1664
Bikes: yes please
Tech question:
Tech question:
#1665
Bikes: Ridley Damocles, CAAD10
I just ordered the Powertap Comp and as I wait, I have a few questions:
1. Can someone explain what the "Interval" display is? When I do my 20 minute Threshold test, is this the function I use or is there a regular "time" display?
2. Ideally, I will want power, speed and cadence all on the same screen. Can I then toggle to get the other stats (time, distance, time of day..etc)? Thanks
#1666
#1667
Roadie
With Wko, you don't really need to use the interval function for your threshold test as you can view the peak 20min, 30min of the ride, but I use it. To get to that function, press and hold the mode button for a coupe of seconds and a "1" will pop up to the left of the speed. Press and hold mode to get back out of the function.
#1668
thanks. So WKO+ allows you to take that 20 minute portion and get an average? Because the whole ride would include warmup/cooldown, but I really want the average power from that 20 minute portion, correct?
#1669
Making a kilometer blurry
2. You can have power, speed and cadence on the screen. The top line can be current power, max power or average power. The second line can be current speed, max speed or average speed. and the third line can be distance, time, current cadence, average cadence, energy, odometer, current heart rate, or average heart rate. You can go to time of day but it is a sequence of buttons. it can not be directly scrolled to. i do not even know how to check it but i know you can.
Some notes:
You can set cadence as your "big" number instead of speed, otherwise you won't be able to see time and cadence at the same time. I find time to be one of the more important data during intervals (especially < 20' intervals). You don't need time of day during an interval
dhale50: I'd recommend you read through the (downloadable) instructions for the head unit and see how intervals work. They're actually really handy. "Interval mode" is what brian416 mentioned, and it always displays information for the current interval (only). So, speed, distance, time, averages, everything is for the current interval. If you hit both buttons at the same time, it starts a new interval. So, for an interval workout, I hold left for 2s, starts interval mode and my first interval. When I finish, I tap both buttons, and "interval 2" will be my recovery interval. Interval 3 will be my next work interval, and so on.
There's also an interval browse mode, where you can change which interval is being displayed (current or past intervals). This is really useful when I'm trying to push negative splits on hill repeats, or during the STUCI intervals, where the pace for the previous interval determines the target for the next one.
#1670
Or, just do the test and WKO allows me to take that 20 minute portion and get the average?
#1671
Great info. So, on my 20 minute test, when it's all said and done, the ride would be about an hour (including warmup and cooldown). Is it necessary to split it up in intervals? For example, interval 1- warmup, interval 2- threshold test, interval 3- cooldown.
I like intervals because I've got a time display for that specific effort. For a 20' test, I would just ride there out of interval mode, hold "Mode" for 2", and start going hard just as the display shows the interval. Now I can glance down and see how much time has gone by. Also, if I look at avg W, I can see how I'm doing against my expected result.
#1672
I personally do not use the interval mode on my powertap. one of the other main screens will display max average power for :30, 1:00, 5:00 and 20:00. also like stated wko will automatically tell you your max power for all different times. the interval function may be beneficial if you want to compare a bunch of say 10 minute efforts. The intervals will allow you to easily get the data for each but really you can just look at the ride and highlight the sections manually.
#1673
Quoted: 31 Post(s)
#1674
I am not super structured as fas as doing exactly 10 1' intervals and such. If I go out and want to do 10 1' intervals doing 1 on 1 off. I will remeber my start time and go until 20 minutes after. If I miss one or do an extra I don't worry about it.
#1675
For workouts like Friel's pace intervals (My training partners and I call them STUCI intervals -- same time until can't improve), you have to use interval mode to know the exact average of your last interval.
Jynx is right though, for less structured workouts, it's not important. It sure is convenient though.
