Winter Brakes
Much better Mr. Buckles
Winter Brakes
are coaster brakes the best type of brakes for winter riding? I think we have all seen the failure of handbrakes when pads get wet (and drum brakes are a bit out of my price range for a winter beater).
Does anyone have any strong opinions/recommendations whether coaster brakes or two handbrakes for winter riding in snow?
Tossed some weight
Bikes: '96 Specialized Rockhopper, '70's Fixed Fuji, '02 Organic Engines Troika Tandem Trike
I gave this some consideration when building my winter bike, but felt that the rear could lock up too easily with a coaster break. Instead I went with disk breaks, since I felt they would not ice up with snow as easily. Sort of the same concept as the drum break solution but less expensive. I don't have any experience to back it up with as of yet.
surly old man
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 46 Post(s)
Liked 42 Times
One good thing about winter riding is that often one is riding slower, so there is more room for error with brakes. Most any braking system can be used well-enough. But some times are better than others.
-coaster brakes are good
-disk brakes are good or great
-road brakes are not so good
-v or canti brakes are pretty good.
-fixed gear, in conjunction with some other brakes, is great
jim
jim
Cross Check Nexus7, IRO Mark V, Trek 620 Nexus7, Karate Monkey half fat, IRO Model 19 fixed, Amp Research B3, Surly 1x1 half fat fixed, and more...
SB forever
SB forever
Quoted: 241 Post(s)
Liked 454 Times
Disk brakes are probably the best for winter...wet, cold, etc...conditions. It is a matter of overcoming the problem of wet and perhaps icy rims and rubber brake pads. Not much you can do when the rims are icy. You aren't going to stop or stop easily.
Disk brakes are at the hub area so they are less apt to ice over. Even wet disk brakes work reasonably well but you still have to be aware there may be a reduction of stopping power.
Bikes: Van Dessel CRB, Giant ATX 880,Footbike track
Ive been using disk breaks on my new ride(country road bob)and so far they are great,pouring rain and they work fine, haven't had snow yet,but im thinking they will be fine.
