Sand Blasting the old steel
Nut
Can anyone tell me if they have ever sand blasted (ie with some soft media) a bike frame at home and what kind of rig you used? I have a bunch of so-so frames that need repainted. I have a good compressor/paint set up, and I'm now looking into paint removal. I have used chemical strippers in the past on "nice" frames, but I am looking for something a little more fun.
Give me the details if you have them!
I am cheap too.
I am cheap too.
Quoted: 380 Post(s)
Liked 106 Times
Have someone do it for you. You will be happier and be healthier if you do. You need a large air compressor that gives out large amounts of air at high pressures. You also need a hood ventilation system to avoid lung damage. You can probably get started for $1000+. Roger
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
rhenning speaks the truth, but just to throw in a little sordid tale: I have used a portable hand-held blaster unit (designed for spot blasting of rusted car panels) and just blasted away in the great outdoors. It should be noted that I was doing this on a registered Super-Fund site, so I didn't feel much guilt about the small bits of paint and large amounts of aluminum oxide I was adding to the dirt, but it's not something I'd ever do in another setting. I had used chemical stripper on the big areas and wanted to speed up the removal around the fancy lugs and braze-ons...it only worked so-so. Cheap spot blasters are available from Harbor freight Tools and other purveyors of "quality Chinese merchandise".YRMV
