Internal gearing in the BB
Got an old Peugeot
Bikes: I had a Trek 1200
Thanks for the link.
This is a good progress, but still you need to have internal gear hub on the back wheel.
I'm looking for a regular hub in the back with one cog.
Thanks,
Kfir
Thanks,
Kfir
Acetone Man
Kfir,
Something similar to what you want can be found in a few exotic freeride/downhill mountain bikes, such as the GT IT-1, Honda RN-01, and Nicolai Nucleon. But if you're looking for a touring bike, this really isn't what you want.
Got an old Peugeot
Hi,
I have seen those, but they are heavy and just 7 speeds.
It looks like they will survive after we fade from the planet
I said Rohloff because its very lite compared to those gearboxes, and also have 14 speeds.
Thanks
Thanks
multimodal commuter
Apparently there is/was a five-speed internally geared crankset called a Miyata FM-5 or something; in the folding bikes forum someone posted a Strida that had been modified with one. Very hard to find, at any rate.
Got an old Peugeot
This is a nice adaptation of the rohloff hub as a front gearbox.
This is what I was looking to find, but, hehe, maybe 1/10 of the price
But it certainly nice to see people adapt known technology and use it differently then intended.
Why does it weights 6.3 kg? My guess it related to downhill where everything should be very stiff.
Thanks,
Kfir
Got an old Peugeot
Yes, now I understand. I saw this thing and didn't bother to read that its rohloff inside.
Thanks,
Kfir
Thanks,
Kfir
I wonder what is the weight of the gearbox itself.
Got an old Peugeot
My intentions when I asked for gearbox like this, was, that it will let the rear wheel be lite without the rohloff hub inside. Also stronger. Was that the intention in the design of the Nucleon?
Thanks,
Kfir
Thanks,
Kfir
Got an old Peugeot
Ok ok, hehe
People did think about this concept before and also went forward to standrize it
https://www.g-boxx.org
Regards,
Kfir
Regards,
Kfir
cyclopath
Bikes: Surly Krampus, Surly Straggler, Pivot Mach 6, Bike Friday Tikit, Bike Friday Tandem, Santa Cruz Nomad
How would the rear wheel be stronger without the Rohloff? A Rohloff wheel has shorter spokes and is not dished which is the equivalent to a 36H/40H dished wheel. People use 32H Rohloff wheels on touring tandems which has to be a pretty brutal application for a bike wheel.
Got an old Peugeot
rohloff hub make the wheel heavy.
It should be in the crank or above like gbox, and let the wheel be lite.
Also then, you will be able to run the belt drive above the crank/chainstays and avoid the opening of the frame for replacing belt.
Kfir
cyclopath
The difference in weight of a Rohloff wheel and a Shimano hub/cassette/der is about 1.75lbs. I'm not sure I could tell the difference on a touring bike - especially once loaded up.
Another thing to consider is that my keeping the gearing in the hub you can quickly move the Rohloff to a 2nd or 3rd bike in minutes by just buying an extra shifter. I'm doing that and it means you suddenly get a whole lot more for your $$$ if you can run two bikes with the same Rohloff.
Got an old Peugeot
I think you didn't understand what I said.
Its a single speed hub at the back and have the rohloff in the crank or somewhere near.
Apperently this was thougt about here: g-boxx.org Techtalk/FAQ's page
If this concept can be cheap, this is a great option for touring bike.
Oh, and again, the concept of sharing rohloff wheel between frames is good, and the g-boxx concept will not have it.
One other thing. Rohloff should be in g-boxx. Its better for a part that cost 1200$. Also it shouldn't be also a hub. Divide and concur. Rohloff will be gearbox and the hub will be a hub. Much better.
cyclopath
I agree with what you say.
Palmer
If you go back to the formative days of bicycle gearing, 1900 to WWI, you'll find a number of bottom bracket multi-gear schemes. They lost out to internal gear hubs because they were on the wrong side of the speed ratio/torque multiplication and had to be stronger (larger, heavier, more expensive).
tcs
tcs
